Rubber Protection.
Old Sep 25, 2009 | 04:28 PM
C_H_A_D's Avatar
Default Rubber Protection.
Ok, here is the deal I build my own squat rack. I am an olympic style weightlifter. So basically I use a somewhat expensive bar. I need to be able to protect it as best as possible.
I will attach horizontal tubing/pipe to the vertical 3" U-channel. I would like to use 2"x2" 1/4" wall tubing. I need a way to cover this with rubber. I can use a different size of tubing or I have some 1.5" sch 40 laying around.
My original design was with 1" round stock but I bent it, from dropping the bar on to it so I need to beef it up.
So how can I put a nice thick layer of rubber around the square tubing?
Old Sep 25, 2009 | 04:37 PM
TunerN00b's Avatar
Default Re: Rubber Protection.
Old Sep 25, 2009 | 05:19 PM
BMCRace's Avatar
go to the pharmacy isle in walmart and get a box of trogan's... I am sure if you put like 5 layers on it will be worthy... lol jking
http://www.mcmaster.com/#rubber/=3si8ue
Try that it is the rubber stock on MCMaster, I am sure the u chanels and some super glue could do the trick
Old Sep 25, 2009 | 06:51 PM
abnaasefmb's Avatar
sawsall and a tire
Old Sep 25, 2009 | 07:31 PM
k24em2's Avatar
Cut up a piece of old tire
Old Sep 26, 2009 | 07:53 AM
srmofo's Avatar
Originally Posted by abnaasefmb
sawsall and a tire
ding,ding,ding.....any kind of coating will get worn rather quickly with the amount of weight I assume you are lifting (just take a look at the equipment of any lower quality gym)
Old Sep 26, 2009 | 06:31 PM
C_H_A_D's Avatar
Well that pic is just a pic I took after I got the weight set. I will regularly be loading 250+ lbs and slamming it on the tubing. I am more looking for a way to wrap it with rubber to make it look more of a custom factory look.
I can find the rubber but I want a good looking wrap around it.
Although I never thought of the tire and that will most likly be the most durable solution.
Old Oct 3, 2009 | 06:47 PM
Froth's Avatar
Uh, why has nobody mentioned Rubber Hose? Just find some 1/4" wall 2" I.D. Heavy Rubber Hose, if you wanted to go even further you could then find some 2-3/8" I.D. Hose to put over the 2" I.D. Hose and just keep layering it that way. I'll say it would be durable enough. You could probably go one step further and find some industrial grade hose with 1/2" wall or more.
http://www.mcmaster.com/#coolant-hose/=3wniqr
Look at the very last listing on that page, abrasive material hose...mostly used for sandblasting and other types of media blasting. the Inner diameter is 2" but the outer diameter is 2-7/8" ! That's some thick *** hose.
-Froth
Old Oct 3, 2009 | 07:14 PM
srmofo's Avatar
becasue he said it was 2x2 tubing. Its like trying to put a square peg in a round hole
Old Oct 3, 2009 | 07:28 PM
Froth's Avatar
Uh, Yeah...exactly. He said Tubing.
Tube, (Noun).
- 1.
- a. A hollow cylinder, especially one that conveys a fluid or functions as a passage.
Round + round = fits well? Yes, I think so. I'm aware that many people call square stock "Tubing" as well, but I was more focused on the fact that he posted this as well
Do we not read the whole post either?
Chad, I'd use a round section of pipe in whatever size you seem to think is necessary and put Hose over it, this will be the easiest and most durable solution that has been mentioned.
-Froth
Old Oct 3, 2009 | 07:35 PM
srmofo's Avatar
ugghh, nevemind somehow I missed the last part of your post and only saw the part where you posted a definition, thats being a passive aggresive jerkoff, sorry for my prior rude response, I tend to get a little irritated with people with attitudes like that. He also stated that he would like to use 2x2. so why not work around what he wants to use?
Old Oct 3, 2009 | 08:09 PM
Froth's Avatar
"This message is hidden because srmofo is on your ignore list. "
Forgive me for trying to help. I forgot this was Honda-Tech. I thought the Weld/Fab forum was civilized, but I can see I was mistaken.
Chad, best of luck with your solution.
-Froth
HamiltonRex
Welding / Fabrication
Jan 16, 2010 08:54 AM
TVT_DESIGN
Apr 11, 2008 07:31 PM
DFW
Dec 9, 2005 09:26 PM
zc911
15
Mar 8, 2003 12:37 PM
ActiveAero
Aug 10, 2002 07:30 PM
