93 hatch cx 1750 f/s and f/t
Location martinsburg wv 25405
ONLY TRADES I AM looking forward to are 92-95 or 95-96 civic 4 door ONLY. WILL CONSIDER 4 DOOR TEGS 94 AND UP ONLY!
car has 133xxx miles on it
car is not legal so no test drives or delivery of car
THE AC MUST WORK OR THE CAR HAS TO HAVE POWER WINDOWS. Auto or 5spd dont matter.
Needs to have minumum work needed to it.
Body condition would prefer to have little or no rust as mine dont. Also consider ones with rust or miss matching body panels
I wont add cash so you need to be equal or lesser value.
Price is firm!!!
Up for sale or trade only for a 4 door civic or teg. The car does not need anything major or minor i just need a 4 door bad. The only issues with car is the driver door locks from out side only as the inside lock handle is broke and car idles low when its cold out.
Pros:
stock.
gsr grey leather
working cd player
stock tach
runs and drives great.
gets 40-50 mpg.
new driver axle with life time warranty
new lower ball joints both side life time warranty
tires have 70% life left
new inspection for wv 8-10 exp.
new front window
front and back gray gsr leather seats worn but no holes and foam is not deterorated
minus the very small surface rust spot the size of a pencil tip eraser. there is no rust elsewhere.
Cons:
No ac... Did not work, tryed to fix it numerous times and all have failed so it was removed.
front bumper was stolen so i replaced it with what ever i could find.
hood is flat black
fart can with gutted cat
low idle
no ant. as its been broken off so cant listen to fm radio
has dx trans
has some wear on seats
has an auto cluster
has a surface rust spot size of a pencil tip eraser on pass side rear
has some clear coat fade on roof
Price is firm!!!
Pros:
stock.
gsr grey leather
working cd player
stock tach
gets 40-50 mpg.
new front window
Cons:
hood is flat black
low idle
has dx trans
has an auto cluster
Shadowcat
May 31, 2014 09:05 AM
80 dolla crx hf
Mid-Atlantic (Sales)
Oct 5, 2009 12:37 PM
80 dolla crx hf
Oct 5, 2009 12:36 PM
