complete GSR built head 1300 obo, 99-00 si cluster, gsr obd1 computer 94-01, part out
1994 Acura Integra GS-R head off b18c1, All work done by ARP:
Comes as seen in picture with dizzy and whatever else you need.
-Head is decked 11:25 around there, decked 10 thousands.
-stainless steal 1mm oversized with heavy duty springs stage
-gsr cams with 45k on them straight from Japan JDM not usdm
-valve cover is powdercoated yellow, but i sprayed it black i can probably get it back to yellow if you want.
-dizzy was bought brand new from napa last fall, 5k miles maybe., car quest wires.
-vtec selenoid
-stock cam gears, stock plastic covers
-if you need all the hoses i can send whatever is not in the pic
-stock intake all new gaskets, just put in put around a thousand miles on them, stock throttle body, all vaccuum hoses needs the top sensor you can see the nipple broke off.
-i have an old exhaust gasket that can go haha.
-valve cover seal is good used once
SI CLUSTER
-bought it off forums but they turned the mileage and it stopped at 70k, it mightve been something in my car because the trip stopped too, all lights work and gauges. looking for 100$ obo
EF GT steering wheel had it on for maybe a year barely driven, looking for 80$ comes with EF hub. all looks brand new horn works.
EF fuel main relay, 20$.
-vtec selenoid
SI CLUSTER
Muuurph
Oct 15, 2009 02:12 PM
