Quastions about a DOHC ZC in a 91 Si Hatch
Old Sep 25, 2009 | 09:01 AM
Redemption's Avatar
Default Quastions about a DOHC ZC in a 91 Si Hatch
Ok so I decided to just ditch the sohc zc since the wiring harness and distributor are missing and just get a dohc zc that I found for a nice price. Now the dilema is this. Since at the moment I have no wiring harness will I be able to use the wiring harness off of the DOHC ZC? I'm going to use the DOHC ZC's ecu because I read it gives you a little bit better performance. Also would I just be able to use my old tranny off of my jdm zc which is a SL3 or will I have to use the DOHC ZC's tranny?
Old Sep 25, 2009 | 09:16 AM
jlicrx's Avatar
Default Re: Quastions about a DOHC ZC in a 91 Si Hatch
you can use the SL3 transmission, no problem - does the ZC have the complete uncut factory ZC harness on it? you can use the factory harness, but you would need to swap a different connector onto either the engine harness or the chassis harness at the driver's side firewall connection - the Si chassis harness has a round 8-wire connector and the ZC engine harness has a rectangular 6-wire connector like the 88 Si
alx_90ef's Avatar
yes the tranny will work with the DONC zc. any d series tranny will work with a dohc zc cuz its a d16.
here this is one of my fav bookmarks..
http://www.phatwhippincrx.20m.com/photo6.html
Old Sep 25, 2009 | 09:48 AM
Redemption's Avatar
Yea I was looking at that website earlier. They didnt say much about the tranny and that's why I wasnt sure about it and they were using the stock si harness which mine got stolen so I was hoping to be able to use the dohc zc's harness. Thanks for the help guys.
jcivic33
Sep 3, 2006 08:49 AM
The Destroyer
11
Dec 30, 2005 02:22 PM
SC-MK1
May 22, 2005 08:51 PM
vtec_head
May 8, 2002 08:59 AM
