how to make a kill switch for your car
Old Sep 24, 2009 | 09:41 PM
JDMlude3189's Avatar
Default how to make a kill switch for your car
does any body know were can i get a write up on how to make home made kill switch for the car
Old Sep 25, 2009 | 09:12 AM
danny_d19's Avatar
Default Re: how to make a kill switch for your car
http://lmgtfy.com/?q=homemade+kill+switch+for+vehicle
Old Sep 25, 2009 | 10:09 AM
4G92's Avatar
lol
Old Sep 25, 2009 | 11:08 AM
crazes's Avatar
Moderator
that was hilarious
Old Sep 25, 2009 | 12:18 PM
Don Jefe's Avatar
Hahaha, kick ***.
Old Sep 26, 2009 | 02:50 PM
Apex1972's Avatar
cut the power wire going to the resistor box. there is five wires altogether but the one you need will be different than the other four. crimp speaker wire to the two ends and run it to a location you have chosen for the switch. connecto to switcho and away you go. easy.
Old Sep 26, 2009 | 03:51 PM
ooo ok i got it now wen i hook that up do i do it before or after were the plugs go
Old Sep 26, 2009 | 04:50 PM
pheurton-skeurto's Avatar
iirc...you can also wire up a kill switch on the hot wire going to the fuel pump.
Old Sep 26, 2009 | 08:25 PM
92civlude's Avatar
I have a pretty good idea for a kill switch. I have it in my car and also a bunch of my buddies have it also. Go to the main relay, Find the "switched hot" for the ECU, tap into the wire, run it to a simple 2way switch, then to ground. Every time you turn your engine off, just hit the switch. When a thief turns the ignition to "on", the ECU fuse pops! Even if he finds the switch and toggles it, its too late! The fuse is already popped, the car wont run.
Old Sep 27, 2009 | 07:08 AM
Apex1972's Avatar
Damn you got me on that one. THat is the best ever.I think I may change mine to that configuration.
Old Sep 27, 2009 | 08:16 AM
92civlude's Avatar
Thanks man. But hey, if it keeps our cars from getting stolen, every idea is a good idea!
Old Sep 27, 2009 | 02:59 PM
Icon2 Re: how to make a kill switch for your car
ok i look today and this is what i got on the left 3 red one yellow on the right 3 black one red which one do i pick and were do i go from there sorry guys that i say this but is just im not good at wiring stuff so i need all the help i can get from you guys
thanks
Old Sep 27, 2009 | 03:11 PM
Twixle's Avatar
ate my pixel
It's only a good idea if you have a spare fuse on your person at all times. The probability of forgetting to un-ground the kill switch when you go to start the car at one point or another is high, especially if it's your daily. Then if the ECU fuse pops, you're out of a car until you find another fuse.
Old Sep 27, 2009 | 06:31 PM
92civlude's Avatar
Before I learned the "new routine", I did pop the ECU fuse more than once! I do keep a handful of extras back by the spare.
Old Sep 28, 2009 | 01:28 AM
HondaKyle's Avatar
that is a good one, I would be blowing fuses left and right tho!
Old Sep 28, 2009 | 06:06 AM
Apex1972's Avatar
if you knew me, you would not even have said that. thanks for playing.
641iowaguy641
Jun 19, 2013 01:53 PM
99fbpem1
Audio / Security / Video
Aug 19, 2007 04:23 PM
FGride
Apr 26, 2006 12:43 AM
Simple
13
Jan 10, 2004 07:57 AM
Want2race
Jan 14, 2003 12:51 PM
