What intake manifold should I choose??
Ok guys here is my setup
ls vtec
1.9 bottom end
12.5 compression
grs head
skunk 2 cams pro series stage 2, valvetrain and gamgears
I am either buying a victor x manifold or skunk 2 maniflod
I am planning to leave all motor but don't know what intake manifold to use
I would love to hear the responses
ls vtec
1.9 bottom end
12.5 compression
grs head
That's not entirely true. The Type R design is a good design and tends to beat the performer X in the very top end on a 1.8L. It also tends to be a good manifold choice for many B20's. They are ALL made for performance, but like all parts, some are better suited for some builds than others and it's up to the individual to determine what that is.
Then at what point in an N/A build does the larger manifolds and throttle bodies actually become necessary? My point is why by bigger if it's not needed?
They become necessary when the rest of the build dictates, it's needed. That's the place where most people go wrong. A larger intake manifold without larger cams and a better header/exhaust system will be of little if any benefit to a build. Add those required pieces and everything compliments each other and solid gains are seen.
Going too big you create vaccum in your manifold , which is not good.
There's a reason why the "whale *****" aka JDM Intake aka Carbon fibar pwJDM intake is a horrible intake..
You can't distort the flow of air like that, and expect to make power.. its all about flow and how fast its flowing.. not how big your dick is..
The Performer X intake works so well on a 1.8L because it's got plenty of volume in the plenum which helps top end power but the runners are longer than stock, to help velocity/torque in the lower-mid range of the RPM range. This is why when compared to a Skunk2 pro intake, the Px makes better power in the low-mid range. The S2 tends to catch it in the 7-8k range because it has shorter runners. The S2 was designed around a stock manifold and therefore has stock restrictions. The Px is much larger than a stock design and therefore has some fittment issues on some cars but will make more power because it's design was optimized more for power than fit.
This is also why custom headers make more power than something like a DC sport header. The DC is basically just an optimized stock design, made to bolt up to stock parts without modification. Custom headers tend to be longer and larger causing the person to do some customizing of the exhaust to get it to fit but will always make more power.
there's a dyno by kingmotorsports where the performer x dynos vs
skunk2 pro series
IB ported itr manifold
victor X
and some other manifold
and the pX ***** on all of them.
skunk2 pro series
victor X
https://honda-tech.com/forums/all-motor-naturally-aspirated-44/intake-manifold-test-results-1-8l-edelbrock-itr-ibspec-take-look-2012979/
PX came out on top.
tegh22a
33
Aug 6, 2006 08:43 AM
