89 ef civic starting problem
i got a 89 ef civic si ....i was on my way to work the other day, and the car started up fine .. i tried to start it up again and it didnt evan turn over at all ...i replaced the starter, and the relay behind the hood latch inside the car... still wont start..... can any one help me?
if the battery is charged then it could be the ignition switch, try wiggling the key around erratically and if it starts for you then it is the ignition switch!
certainly sounds like it could be the ignition switch at fault. test it out
http://mycomputerninja.com/~jon/IgnitionSwitch.html
if the ignition switch goes bad will that cause my radio and dash icons to come on like they should when you turn the key? my battery is fully charged and my dome light and head lights all work but when you turn the key nothing happens no radio no dash icons nothing can anyone help?
aninfinitebeing
Feb 10, 2013 07:48 AM
91hob20hb
Jul 17, 2004 11:16 AM
Honda Virgin
Jun 2, 2004 12:34 PM
