accord wagons
Old Sep 24, 2009 | 04:54 PM
nicolas1320's Avatar
Icon6 accord wagons
hi my name is nick and i have a question for the accord owners. I have a 96 wagon with a rear swap,''so they say'' its a 2001 H23a v-tec engine. Its running fine but i think its running kind of rich. I have a obd2 p73 type r ecu, i want to know if this is safe for the motor or if i can tune this ecu. thanks.
Old Sep 25, 2009 | 03:13 PM
P_Adams's Avatar
Default Re: accord wagons
What indicators point to it running rich?
If the swap was done correctly (read that as "completely") there would be no difference as to it being stock.
P
Old Sep 25, 2009 | 03:34 PM
well the egr sensor was not connected because the p73 type r ecu does not read one, but i think its running rich because the exhaust smells like more gas. the motor has no smoke ether black or white or blue, it just has a very strong smell. if is posible can you let me know if the egr sensor from the H23a motor is the same as the accord obd2 or the prelude H22. thanks:
Old Sep 25, 2009 | 03:46 PM
also the the type r ecu is intended to control a 1.8 not a 2.3 thats why i ask if its safe to run the motor with this computer. thanks
Old Sep 25, 2009 | 07:59 PM
P_Adams's Avatar
1) are you speaking of the EGR Lift Sensor?
2) You may indeed need to remap the injector curves. I believe because of both the displacement change and the Injector flow rate changes.
I'd pull a spark plug and interpret the insulators color. It should be sampled after the vehicle has fully warmed up and driven a few miles.
You are looking for a center electrode which is the color of a Dunkin Donuts coffee, extre extra light.
If you're seeing a chalk white electrode, it's too lean
If you're seeing dark chocolate or it's sootie, then you're too rich.
P
Old Sep 26, 2009 | 02:47 PM
ok cool,i will check that. ohh today i went to a shop called project jdm and asked about that problem, he offered me the hondata 3oo he said that i can use this to tune my computer for that motor.Just hope that will resolve the problem.thanks
Damon Absheer
Oct 24, 2016 12:11 AM
TrademarkAccord
May 6, 2013 04:31 AM
Dominicandude
Engine Management and Tuning
Nov 9, 2012 03:17 PM
