89 si tranny
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/stock-clutch-fitment-guide-2284956/
mostly flywheel diameter
use the 91 flywheel and clutch - the transmission you use with the larger 90-91 flywheel and clutch doesn't matter as long as the transmission isn't 88 model - all 89-91 transmissions will work with any 89 clutch and flywheel or any 90-91 clutch and flywheel
Correctomundo! Yeah I had a 89 si tranny with a d15b vtec in my 91 dx, used my 91 dx clutch and flywheel on it, everything worked fine. It's sitting in my garage now only cause the diff broke in it, but that's my fault.
the DX Final Drive has 18 teeth on the countershaft and 70 teeth on the ring gear
I have a zc vtec in there now, which is basically a d16z6. I like that swap, I like it better than my d15b vtec. Mainly for the torque, I used to have to downshift my d15b vtec down to third gear when exiting onto an onramp. With my zc vtec I can keep it in 5th if I want and it won't act like it's about to bog out on me like the d15b vtec did.
21 spline 190mm came in 88 crx/civics
21 spline 200mm came in 86-89 teg/79-87 prelude
20 spline 200mm came in 89 crx/civics
20 spline 212mm came in 90-00 non-b series crx/civics
21 spline 212mm came in 84-87 2.0L Preludes
19 spline 190mm came in 73-80 civics
19 spline 200mm came in 81-87 civics
19 spline 190mm came in 84-87 crx
24 spline 210mm came in 88-89 prelude
24 spline 220mm came in 90-95 prelude non-vtec
24 spline 225mm came in 94-99 prelude vtec
EJ1 wilcox
10
Sep 9, 2005 08:06 AM
CRXalwysk8
13
May 3, 2005 07:18 AM
sohcvtec66
Nov 18, 2003 09:49 AM
