Does spray can mold release gel exist? Ttrying to fiberglass copy my headlight lens.
Old Sep 24, 2009 | 02:30 PM
brokenojoke's Avatar
Icon2 Does spray can mold release gel exist? Ttrying to fiberglass copy my headlight lens.
I'm trying to make a mold of my EF headlight lens which is made of glass. Before I just go laying resin and fiberglass directly onto the glass, is there a mold release gel/spray that I can/should use? I've found plenty of stuff for pro shops that they sell by the gallon, but none of it says it works for glass. Anyone done this before?
Thanks
Old Sep 24, 2009 | 02:31 PM
Default Re: Does spray can mold release gel exist? Ttrying to fiberglass copy my headlight le
Or better yet.... does anyone make an insert already?
Old Sep 25, 2009 | 06:02 AM
DeathInACRX's Avatar
i think you can use vasoline. im sure there are cheep alternatives than a pro shop has to offer. maybe if you masked the whole thing with painters tape, or spray foam on the glass with a release agent of course and then when its dry carefully remove the foam from the lens so that the foam is now a negative mold and then lay your fiberglass in there to make the insert that you want. that is what im going to try out when i get to that stage in my crx build. it would hurt to try right? peace
reddcliffe
Detailing
Aug 25, 2016 04:16 PM
GoLowDrew
Detailing
Jun 14, 2012 12:23 AM
hanginlow
Apr 29, 2003 04:34 AM
rurkster
Nov 16, 2002 03:06 PM
98civicR
12
Nov 4, 2002 06:10 PM
