quick dohc zc tranny question
the Si final drive is shorter which gives you better acceleration in gears 1-3, although the stock ZC (with the longer final drive) has shorter 4 and 5 gears than the Si - with the Si final drive in the ZC transmission, it is geared even shorter because the ZC 2-5 gears are all shorter than the Si 2-5 gears
hmm well i kinda got what you said....
so if i put the si final drive in the zc it will shorten all the gears?
See if you can get the Sedan EX FD.
ZC 1~3 and Si 4~5.... or HF5th since it looks like a good freeway gear.
Personally I like a little power in 5th... HF might be gutless and have you down shifting just to pass people.
PS: the ZC 5th with Si FD puts you at about 4300rpm at 80mph.
Modern91Hatch
Apr 25, 2008 08:38 AM
