How do I stamp a 1 after H22A
Old Sep 24, 2009 | 11:00 AM
butter99's Avatar
Default How do I stamp a 1 after H22A
How do I stamp a 1 after H22A. What can i use thats cheap enough to stamp a nice and neat number on my engine block? please no giggles..I just want constructive information.
Old Sep 24, 2009 | 11:11 AM
Sales@Bisimoto.com's Avatar
Default Re: How do I stamp a 1 after H22A
may i ask why you would want to do that?
Old Sep 24, 2009 | 11:20 AM
#1rudebwoy's Avatar
Truthfully that makes no sence....lol but then again see where you live.... go to home depote and they have number pins that they sell and all you need is a hammer to stampa the block.
Old Sep 24, 2009 | 11:27 AM
butter99's Avatar
Looks like harbour freight carries metal stamps. My friend can't pass the ref inspection because the H22A is JDM. California standards apparently won't allow a A 95 JDM H22A in a 93 US civic hatch. So he needs a 1 after h22a to make him happy. (:
if you have any other info please let me know.
Old Sep 24, 2009 | 12:03 PM
jlude90's Avatar
they know the difference between a jdm and usdm block? when there is exactly 0 difference between the two? If they can pick that out, you don't think they'll pick out a freshly stamped number thats a different style/size then what Honda did, and will probably be crooked? Can you get in trouble for some kind of fraud with this?
Old Sep 24, 2009 | 07:05 PM
Colby71's Avatar
You could sand the numbers off and stamp the hole h22a1 back so it is in same font and size.
Old Sep 24, 2009 | 08:39 PM
my9thtry's Avatar
Higher compression ratio,
Im glad i live in florida GOOD LUCK
Old Sep 24, 2009 | 10:09 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Cali Refs know as much about Honda engines as most people on this board. Hell Im a smog tech and I know more than most, cant fool me.
Old Sep 25, 2009 | 09:15 AM
h22 civic's Avatar
You don't want to do that. Depending on the inspector you might be walking home after that
Old Sep 25, 2009 | 10:53 AM
NirVTEC's Avatar
x2
Thats fraud and I'm sure they could tag with a few other violations too.
Way to try to beat the system and end up with no car....
One day, people will be smart enough to think about stuff like this before they throw their car together. The issue has only been addressed like 23964298 times.
Old Sep 25, 2009 | 11:40 AM
jlude90's Avatar
I know what the internal differences are, but the blocks are identical. If you put JDM pistons in a US engine, would it be illegal?
Old Sep 25, 2009 | 12:05 PM
NirVTEC's Avatar
It would be as legal as using some sort of aftermarket piston in a USDM block. Is that legal?
Its a little funny to think someone would do that [after] now.
OP, tell 3 friends about this so others don't make the same mistake.
Old Sep 25, 2009 | 12:44 PM
jlude90's Avatar
It is in my town, if you aren't throwing any extra emissions out the butt and can still hook a scanner or whatever then you're fine, right?
I don't know how the left side of the country works but we're emissions free here in sunny FL.
Old Sep 25, 2009 | 12:56 PM
darkstarsinner's Avatar
Same here in most of Ohio. The next county is getting rid of the E-check early because it's been proven useless. Sorry about you Cali boys. Just swap the motor out for inspection and swap it again later. It's a lot of work yeah but you will need to detemin if it's worth it.
Old Sep 25, 2009 | 02:41 PM
NirVTEC's Avatar
Exactly why guys need to start thinking about stuff like this before they swap.
Its like the obd2 guys doing big builds/turbos in Chicagoland, swapping to obd1 and then being screwed come emissions time. They can barely get the car to run with obd2, much less go to emissions with no CEL.
Old Sep 26, 2009 | 06:21 PM
butter99's Avatar
wow good info and yes it is very shady. If i did accomplish adding a number would I still run into the problem with the horsepower the refs computer or compression or somthing. Im really not in the mood for swapping another h22a1 in and getting it inspected.
Old Sep 26, 2009 | 10:01 PM
THC07's Avatar
go to a different ref. I know that here in norcal they dont like the jdm motors. but some of them will ref it.
In yuba city i have seen a few jdm motors get passed. You might have luck at Butte college as well. some will some will not.
Old Sep 27, 2009 | 03:27 PM
Twixle's Avatar
ate my pixel
You think they're not going to run the VIN when the car and engine don't match?
Old Sep 27, 2009 | 03:31 PM
dagle's Avatar
show me a vin on an OBD1 or JDM motor?
Old Sep 27, 2009 | 05:49 PM
night's Avatar
you could use a small chisel to mimic the honda font... but i live here in sane land where only the actual emissions matter and not some random sht they decide they don't like.
or if you have ocd you could put it to use by taking a fine craft hacksaw to a junkyard and trimmer off the full usdm mark and using some aluminum epoxy to put it on the JDM block o.O .
i dunno.. i just pulled that outta my ***.
Old Sep 28, 2009 | 09:32 AM
THC07's Avatar
Just talk to different refs. Some will, some will not. as I said, i have seen a few pass throguh Yuba city.
Old Sep 28, 2009 | 03:17 PM
butter99's Avatar
I see..
Cutting a code from a junkyard engine was a fun idea LOL
If i could find a ref that was a bit more lenient or less educated that would be ok with me. If anyone knows a ref who might pass me please pm. (:
otherwise I'm still looking for an H22a1 hopefully just to borrow.
Old Sep 29, 2009 | 09:46 AM
NirVTEC's Avatar
Originally Posted by butter99
I see..
Amazing what you guys will go through......Why not just build a motor to beat the refs?
Seems easy enough. Insert TypeS pistons into an h22a1 block with h23 crank/rods.
Old Sep 29, 2009 | 03:20 PM
JDM_CD7's Avatar
For 23 years of age OP, your not the sharpest tool in the shed.
Thats why you should follow NirVTEC's idea and just find a USDM block and build it.
Out smart the system, don't get caught doing fraud.
Reh-Tard
Old Sep 29, 2009 | 04:03 PM
NirVTEC's Avatar
Reh-Tard
I just don't understand why they don't do that in the 1st place.....
You know how many obd2 guys I have woken up regarding stuff like this?
