B16 Turbo Cams?
Just wondering what kind of cams I should get should get for my B16a2 that im about to turbo. Right now I got a set of Buddy Club Spec III+ cams with adjustable cam gears and titanium springs/retainers. Someone told me that I cant use these cams with a turbo setup cuz there will be to much overlap. Is this true? I was thinking about buying some TYPE R cams if I have to change them out. Tell me what u think.....................Thanks in advance.
I would recommend the Bisimoto Level 1.2 turbo cam
Bisimoto makes the best Camshaft in the industry.
1)We Scientifically designed in house for specific engine codes. This means the best power and reliability for your application.
2)Bismoto cams exist in stages, and not a one size fit all. This simplifies your buying decision.
3)Bisimoto Cams have Dyno and track proven performance. This gives you the confidence that your purchase is the right one, and works.
4)We have custom grids, unlike the competition.
It differentiates you from your friends and competitors, and also offer you a solution for your unique build. And it allows for the most powerful camshaft designs ever: if you like a competitors cam, we can make it better! For example, if you like the competitor's camshaft bottom end but not the mid-range, we can change the mid-range to suit your likes.
We have seen gains of 70hp over factory cams at 15psi boost!
Contact me if you have any more questions
OK so i got the type r cams but i think that they are a little worn out. Is it ok to put these in or will it mess up my rockers? Hopefully this pic works.
