fuel injector problem!
alright you guys ive been on this problem for about 2 weeks now, and i think ive narrowed my problem down to fuel injector problem. I have a obd1 b16 in my 88 dx hatch.... so ill give u a brief description of my problem. when i start my car, once warm it will misfire and run like crap, it will misfire while im idling and driving below 3000rpm, once i get passed 3000 rpm, i still feel loss of power. so i decided to do a full ignition tune up, (cap, rotor, plugs, and wires) and changed fuel filter, checked my timing and still same problem. so i finally gave up and took it into vegas shop called "Hondoctors" they charged me $110 to tell me it was in cylinder 2 and that i had good compression in every cylinder(they did cylinder leakdown test), so eliminating HG problem. they also said all my ignition parts where working properly and they said it could misfire could be due to sticky valves or valve clearances being to tight. so i decided to buy a new fuel injector and replaced cylinder 2, and miraculously my huge misfire stopped and i had more power. i was still misfiring a little bit. anyways today in the morning it started doing it again. So this time i pulled out my multimeter and while the car running i checked every injector clip and cylinders 1,3,and 4 showed about 14V, but cylinder 2 only showed 7V, which gave me a huge break. because that is one of the wires that is messed with in dpfi to mpfi conversion. i checked the positive prong on connector and used a stronger ground and i was getting 14V on cylinder 2, but only 7 when i used the ground on the connector. i also used the ground on the connector and checked my battery voltage and it showed that my battery was only at 8V, which i know was incorrect cuz i had my s300 hooked up to my laptop and on the datalog it showed 14V. so im guessing i have a bad ground, but i dont know how far to go with the wire, cuz the wire has a couple of solder points here is a small sketch
*: means solder point
---:wire
EcuA3---*-----*inline fuse*------*connector in engine bay*--------*injector connnector
the problem is that when i use grounds straight from obd1 pins A1,A3,A5,A2 (obd0 pins A1, A3, A5, A7) when car is running, and check for batt voltage on battery i only get 1.5V, but once they reach injectors they all give good grounds except for cylinder 2. oh and when car is turned off, cylinder 2 connector gives me a good ground cuz when i check it on my battery it gives me 12V. so could this also be an ecu problem?
---:wire
DrRoboto
Sep 22, 2011 04:29 PM
spock_rocker
Apr 20, 2004 05:35 PM
