SWAPPED TRANNY, NOW GAUGE CLUSTER DONT WORK - Pls HELP
swapped the grinding tranny out of my 95 GSR, bled the clutch and took a drive. everything works fine EXCEPT my gauge cluster...NONE of the 4 of the gauges work, only half of the cluster lights up when i turn on the headlights. could it be the VSS and would it affect the whole gauge cluster? i dont have an ohm meter so i gotta trouble shoot by guessing for now. everything else electrical works, including all lights. checked the fuses...theyre okay. only thing i did was swap trans, bleed clutch.
PLS HELP if you have any advice. thank you.
