balljoint bolts stripped help!!
Old Sep 23, 2009 | 11:02 PM
TypeRMOBBiN209's Avatar
Default balljoint bolts stripped help!!
well i just got done swapping a motor in my integra and now im at the part where i put the axles
there is a balljoint with a bolt on the top where the hub assemly connects too and another at the bottom where it connects to the control arm
both of the bolts are stripped and i cant get the castle nut on...is there a way i can fix that without having to change out the whole assembly?
thanks
Old Sep 23, 2009 | 11:09 PM
c1_sleeper's Avatar
Default Re: balljoint bolts stripped help!!
look into a tap and die kit. they might have one for that size bolt and pitch. also for future reference, if u didnt know already, u only have to take the lower control arm ball joint out and swing the brake assembly out the way
Old Sep 24, 2009 | 12:04 AM
sik96teg's Avatar
u can get a new lower ball joint at autozone for 30 bucks and rent there ball joint removal/installation kit.
Old Sep 24, 2009 | 01:04 AM
alrite thanks guys...yea i know you only need to take off the bottom i dont know why i took off the top
does anyone know the size and pitch to them both?
Old Sep 24, 2009 | 03:09 PM
srmofo's Avatar
did you whack them with a hammer while trying to remove them? we all learned that lesson the hard way the first time too
Old Sep 24, 2009 | 03:11 PM
srmofo's Avatar
check here for the size it may be listed somewhere
https://honda-tech.com/forums/tech-misc-15/common-honda-bolt-thread-pitch-size-dimension-1885652/
if I had to guess I think 11 x 1.25...maybe even 12x1.25
Farquea
18
Apr 15, 2018 05:57 PM
phantoms
Honda Civic (2001 - 2005)
15
Aug 12, 2013 02:52 PM
dungsta
Jun 7, 2005 05:13 PM
Dseriespower
10
Dec 7, 2003 08:09 PM
ScottEK
17
Sep 21, 2002 06:23 PM
