AEM Fuel Rail
Old Aug 28, 2002 | 07:01 AM
RacerXintegra2k's Avatar
Default AEM Fuel Rail
I'm curiouse .. what does a fuel rail do .. and is it easy to install ?
Old Aug 28, 2002 | 07:43 AM
LTB420's Avatar
Default Re: AEM Fuel Rail (RacerXintegra2k)
It just supports more fuel flow to your injectors. It's not that hard to install just remember to lube the injector o rings with a little oil beffor sliding them back into place.
Old Aug 28, 2002 | 08:19 AM
RSA_teg's Avatar
Default Re: AEM Fuel Rail (LTB420)
wut if u didn't lube the o ring then wut??
will it leak??
Old Aug 28, 2002 | 08:46 AM
LOwrestling2001's Avatar
Default Re: AEM Fuel Rail (RSA_teg)
no but u risk tearingthem.
Old Aug 28, 2002 | 08:55 AM
JDubya's Avatar
Does it help or hurt anything to put this on a farily stock motor? like no other fuel mods, no turbo etc...
Old Aug 28, 2002 | 11:45 AM
lsteggy's Avatar
Default Re: AEM Fuel Rail (Hybrid Teg98)
yea always lube them cause i tore one and that sucks ***. gas gets sprayed everywhere. i was lucky that it didnt catch on fire.
Old Aug 28, 2002 | 11:49 AM
GSRwBOOST's Avatar
Default Re: AEM Fuel Rail (lsteggy)
it's not needed unless you have large injectors... large injectors can empty the fuel rail and thus needeing a larger aftermarket one..
unless your turbo or supercharged andputting out 350-400 hp. i think ou should invest your money in some cam gears or some flowers for your mom.
I have one just because i needed to add a fuel pressure gauge... and it has a spot for the regulator AND a fuel pressure spot..
CoastalSi
Dec 21, 2010 08:01 PM
Shadow Templar
Jan 30, 2004 08:25 PM
jazz215
Sep 14, 2003 09:17 AM
pureplayaz704
Mar 29, 2003 11:55 PM
thehondaguru
Oct 11, 2002 05:33 AM
