Will injectors from a 1996 Civic DX work in a 1991 Civic DX?
Old Sep 23, 2009 | 04:45 PM
78CITYTURBO's Avatar
Default Will injectors from a 1996 Civic DX work in a 1991 Civic DX?
I did searched. Just curious...thanks.
Old Sep 23, 2009 | 04:54 PM
D16SiHatch's Avatar
Default Re: Will injectors from a 1996 Civic DX work in a 1991 Civic DX?
96 dx injectors are 190cc and 91 dx injectors are 240cc. so no they wont work. it would run lean
Old Sep 23, 2009 | 06:37 PM
beansandrice's Avatar
Well if you have a 91 civic DX You only have 2 injectors.
The 96 (ek) civic DX has 4. What do you want to do? Are you MPFI converted or you want to rock 2 of the 4 EK injectors?
Old Sep 23, 2009 | 06:57 PM
k20aed6's Avatar
u can use ek injectors onna EF if u gotta mpfi manifold, u jus gotta eleminate that old *** resistor box...i did a multiport swap onna ef wit every ek intake part
Old Sep 25, 2009 | 10:23 AM
Thanks for the input guys. Well, I have a 1991 Civic DX, 4 dr. It'll crank but won't turn over. I'm getting infos now so I can work on the car tomorrow. I will check the main relay, fuel pump, distributor, coil, igniter, starter, injectors, plugs. I'm just curious if 96 Civic DX will work on a 1991 Civic DX since I have some extra 96 Civic DX injectors. Thanks guys.
Old Sep 25, 2009 | 10:56 AM
alx_90ef's Avatar
you'll need the obd2 clips also
dcsleeper408
Oct 23, 2014 01:37 PM
Josho_17
Mar 20, 2003 04:50 PM
