'91 Accord heater won't shut off.
Old Aug 28, 2002 | 06:09 AM
Hippie's Avatar
Default '91 Accord heater won't shut off.
Drove the Accord to work for the 1st time today. Was wondering if it would put out good heat this winter, I believe it will as it is stuck on ! Got pretty damn toastie real quick. I assume the valve is electrically operated, is this a common problem ? Which is the most likely the rheostat (switch) or the valve ? Wasn't so bad coming in because it was cool and I just rolled the windows down but it is supposed to warm up and rain this PM which will really BITE as the AC isn't working either. Got a bearing going out in the accessory drive too sounds like, wasn't making noise when I left the house but was when I pulled in. Alternator, compressor or idler, oh well gotta expect stuff like that when they've been parked for any length of time.
Old Aug 28, 2002 | 12:47 PM
Perfectionist's Avatar
Default Re: '91 Accord heater won't shut off. (Hippie)
If it's like my old '92, the heater's temp is controled by a rotary ****. Pull the **** off and check if the shaft part of it is broken. A common problem. About $4 at the dealer, sometimes free.
Old Aug 28, 2002 | 05:57 PM
Hippie's Avatar
Default Re: '91 Accord heater won't shut off. (Perfectionist)
Give that man a ceegar ! That was it. Thanks!!!!!!!
Kind of surprised it's a rotary cable control, felt just like a potentiometer or rheostat. Not complaining, the simpler the better.
[Modified by Hippie, 11:50 AM 8/29/2002]
CJHopper
Transmission & Drivetrain
May 5, 2018 06:59 PM
valley4130
Jul 31, 2009 06:04 AM
EGhatch33
Jan 30, 2007 07:42 PM
gdhall
Sep 11, 2006 01:44 PM
Nirvanaspartan
Jul 20, 2005 03:04 AM
