NY 1997 Civic EK9 Clone K20a2 Swap with K Pro
The CTR clone comes with a modified K20a2 engine.
BC stage2 cams springs and retainers and flat valves bringing the CR up to the JDM spec's.
The car also comes with new upgrade internal engine parts, custom made 12.66 CR Wiesco pistons with eagle H-beam rods with new mains and rod bearings. These parts are new in the box not installed
The six speed tranny is also equipped with a Quaife differential with a ACT Six puck clutch and pressure plate and Drive Shaft Shop Co. Stage1 axles.
This car also comes with an extra set of JDM 10 spoke 16" wheels and tires. The suspension is JIC Magic, rear camber kit and suspension tech. sway bars. The brakes are diamond drilled and slotted rotors and HD pads.
The car is selling for 15k.
This car is one of the best CTR clones you'll ever see, and you will be very impressed with the K swap tuned on K-Pro the car still has fully functioning power steering and A/C.
Plus much more. Please email me at shajarah@gmail.com
Last edited by 93civiceg6; May 9, 2010 at 04:26 AM. Reason: New Low Price 15K Takes It.
