Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Trunk Garnish
Old Sep 23, 2009 | 02:27 PM
toadolson's Avatar
Icon2 Trunk Garnish
This might have been covered but I did not get the answer I am looking for with a search.
I just purchased a 09 alabaster silver si sedan. The chrome trim piece over the rear plate is driving me nuts. It does not match the rest of the car. Doing what research I can, it looks as if I can use a color match piece from a 08 civic hybrid.
Has anyone got a straight answer to give. All I've incountered is a bunch of MAYBE'S. Thank's again guys.
Old Sep 23, 2009 | 02:46 PM
FijiBlueFG2's Avatar
Road House
Default Re: Trunk Garnish
You could even paint it yourself.
ASM is not an Si-specific color, I don't believe, so you should be all set if you get one from another trim of Civic.
Old Sep 23, 2009 | 02:57 PM
Kidnkorner's Avatar
You can get an 2007-2008 trim piece and it will fit. I don't care for the chrome trim piece either.
Here is the part number.
This the Si part # 74890-SNE-A11ZE
Here is the EX/LX/DX part # 74890-SNA-A11ZG
it comes painted too!!!!!!
Old Sep 23, 2009 | 03:29 PM
toadolson's Avatar
Thank you for the rapid reply. That is the part # I was given with the maybe. Thanks. T
Old Sep 23, 2009 | 05:09 PM
av911's Avatar
http://collegehillshonda.com/honda-c...ccessories.htm
Old Sep 23, 2009 | 07:27 PM
Kidnkorner's Avatar
http://www.hondapartscheap.com
28% off list
Old Sep 26, 2009 | 09:40 AM
Ricey McRicerton's Avatar
Wow, I figured the replacement panel would be a lot more than that. I may end up swapping mine out.
Old Oct 23, 2009 | 04:59 PM
toadolson's Avatar
I can't say enough thanks. The part came in today and fits like a glove. Perfect color match and no key hole.
Old Oct 23, 2009 | 05:50 PM
tomh1979's Avatar
gotta keep in mind though, the DX and LX garnish will have a key hole, the EX and Si should not, though i have seen a few new Si's hit our lot with them for some strange reason.
Old Jul 13, 2010 | 07:28 AM
na+b18c_hatch's Avatar
resurrecting this thread....
has anyone done a DIY paint job, painting the chrome trim black?? i'd like to see it if it's been done. I have an 09 sedan, redline orange pearl (si-specific). any ideas or pictures??
thanks in advance guys.
Old Jul 13, 2010 | 10:42 AM
That orangle pearl has a metal flake to it, right? That's going to be rough to paint match.
Old Jul 13, 2010 | 10:46 AM
yeah that's why I was thinking of painting it black... there's no other chrome on the car, the front grille is black. i think it would look ok, but if someone has a picture of this I'd greatly appreciate it.
Old Jul 13, 2010 | 11:06 AM
2008fijibluesi's Avatar
They sell the piece in various colors there....not in ROP but they do sell it prepainted in black.
Old Jul 13, 2010 | 11:38 AM
alright cool, thanks man. if i'm guna go black, i might just do it myself.
btw, i'll post pics when i'm finished so all you redline orange si owners out there can see the difference lol...
Old Jul 13, 2010 | 01:18 PM
BTW your car's brand new...it's not gonna be very hard to paint match a small little piece like that trim piece. Get a spray can of ROP and you'll never notice a difference if you prep it correctly.
Old Jul 13, 2010 | 01:34 PM
I stopped by AutoZone and Advance Auto Parts today at lunch and DID look, but couldn't find any ROP in a spray can... i suppose it's still too new of a color for them to carry it. Worst case scenario: my buddy does paint work for a collision center and could mix me up a batch. I'm curious to see what it would look like black though (redundant, i know lol).
Old Jul 13, 2010 | 10:26 PM
https://www.paintscratch.com/cgi-bin/place_order2.cgi
There's a site where you can order ROP in a spray can, in case you do decide to go with ROP.
Old Jul 14, 2010 | 04:27 AM
Ok that's awesome man.. thank you!
Old Jul 14, 2010 | 09:28 AM
Metal flake sprays differently based on pressure/nozzle/etc. I absolutely agree with you that it's a little piece, and it likely won't be noticeable, but it may not be perfect.
I swapped mine and made a thread about it. Removing it's not too bad at all, just get some angled needle nose pliers.
Old Jul 14, 2010 | 09:44 AM
Yes...I agree it might not be perfect, but if prepared correctly, it might be perfect, and would likely be unnoticeable if it isn't perfect. A buddy of mine messed up the grill on his HRP FG2, and he got a NHBP replacement for cheap. I resprayed it HRP and matched it perfectly. I just used a few light even coats. It's much easier to hide poor prep and painting techniques with non-pearl paints.
Old Jul 14, 2010 | 09:53 AM
how are you guys prepping? sanding and priming? or just a little paint thinner on the surface?
Old Jul 14, 2010 | 10:36 AM
With something like the trunk trim, that really shouldn't have any imperfections, you just need to sand the surface smoothly and give the primer something to grab. Make sure you sand evenly. I'd use a quality primer and spray a couple coats with a flash dry time in between each coat. Let the primer dry fully (shouldn't take long), and I'd sand the primer, although you don't need to. If you do sand the primer, make sure the surface is clean (free of dust) and dry before you paint it. Use a couple light even coats of HRP (as many as it takes to match your trunk...with flash dry time in between) and let them dry fully. I'd wetsand the paint til it's silky smooth, and make sure it's absolutely clean and dry. When it's clean and dry, coat with one or two coats of clear. Let the whole thing dry fully overnight before touching it at all.
I'm not a professional painter but this method has worked perfectly for me many times.
Old Jul 14, 2010 | 11:38 AM
Fiji... good tips man, thank you. I've done some light paint work myself but nothing serious. I painted a set of blades for my old dc that came out pretty good, but i've never done any color-matched paint work.
as for wet-sanding.. i wet-sanded and polished the comptech header that i installed on my old eg and that came oyt pretty good. what grit sandpaper would you recommend using on the chrome surface? the primer?
thanks again man
Old Jul 14, 2010 | 02:16 PM
Ross's Avatar
25 Year Member
Community Builder
Community Influencer
Active Streak: 30 Days
ROP owner here. I've been thinking about this a lot.
Old Jul 15, 2010 | 03:40 AM
does the chrome bother you like it does me?? its sooo EX lol.. if i paint mine this weekend or sometime soon i'll post pics so you can see and make a decision.
