No Spark, No Codes???????
Old Sep 23, 2009 | 01:11 PM
seldon's Avatar
Default No Spark, No Codes???????
Hey i was cruising down the highway when all of a sudden my integra just died, i checked the fuel pump and it was working fine then i checked the spark and it's got none.
It's a jdm 98 integra, the wiring is converted to obd1. It has a ls/vtec and the ditributor is brand new (although i know they can still break). any ideas? there was no warning the car just died and it is not throwing any codes
Old Sep 23, 2009 | 01:17 PM
mrdeadman's Avatar
They let me pick
Default Re: No Spark, No Codes???????
timing belt.
Old Sep 23, 2009 | 03:14 PM
seldon's Avatar
no, the timing belt is good. is it possible my ecu went?
Old Sep 23, 2009 | 03:45 PM
95DC2GS-R's Avatar
Coil.
Old Sep 23, 2009 | 05:06 PM
mrdeadman's Avatar
They let me pick
Did you check it? Sometimes the belt won't snap, but teeth will shred off...
Old Sep 23, 2009 | 05:34 PM
seldon's Avatar
i didn't actually check it but the car does not roll over fast, and it's a brand new oem timing belt
Old Sep 23, 2009 | 05:56 PM
95DC2GS-R's Avatar
It's the coil.
Mine did this same thing two days ago.
Old Sep 23, 2009 | 06:31 PM
mouab18c1's Avatar
im leaning towards the coil myself..take it to autozone..free testing
Old Sep 23, 2009 | 06:34 PM
seldon's Avatar
i live in canada, no autozones here, so is the coil hard to change, anyone got a link? thanks
Old Sep 23, 2009 | 06:40 PM
mouab18c1's Avatar
damn that sucks..and no the coil is simple to remove...you dont have any shops that would do tests for free?
Old Sep 24, 2009 | 04:07 AM
seldon's Avatar
nope, no shops, i heard the internals in the honda distributors are interchangable. any truth to that? also would some of the internals, ie) ignitor, coil, etc, from a 94 accord (4cyl) fit in my vtec distributor?
Old Sep 24, 2009 | 06:53 AM
mouab18c1's Avatar
im not sure about accord coils but from what i heard.. ls coils are interchangeable with vtec dizzy's
Old Sep 24, 2009 | 07:44 AM
dimes10's Avatar
ECU for sure. This exact thing happened to me years ago.
Old Sep 24, 2009 | 06:22 PM
95DC2GS-R's Avatar
The coil is very easy to change. Remove ditributor cap, remove rotor, unscrew coil with the 2 screws, unscrew the wires (2) from the coil, and the coil can be slid out.
9/10 it's the coil. A bad coil can test within spec (ohms) and a good coil can test out of spec but still work. My burnt out coil read fine with an DMM.
bart simpson
Oct 21, 2012 08:02 AM
lsvtek
May 11, 2008 11:06 PM
KCFA1250
Mar 31, 2008 07:00 AM
sleepyhamsterlx
Jul 3, 2006 07:19 AM
the soL that could
11
May 30, 2006 07:58 AM
