Problems of adaptation for the Ecu
Old Aug 28, 2002 | 04:54 AM
typer558's Avatar
Default Problems of adaptation for the Ecu
Hello boys,
I wanted to ask you if the Ecu of the RSX has the same problems of adaptation to one exhaust racing. On my Honda Civic Type R (EP3 – K20A), in fact, I have installed a SuperSprint cat-back -diameter 63.5mm- and my Ecu has begun to give problems of detonations in the exhaust, before the catalyst.
This problem verification when rain. The catalyst is cooled off too much (because of the reduction of the backpressure with to the exhaust racing) and the Ecu (the second probe lambda), in order not to pollute too much, fattens the carburation.
Someone of you has had similar problems having mounted one exhaust racing on the RSX?
SuperSprint exhaust: +9hp
[Modified by typer558, 10:05 AM 8/29/2002]
Old Aug 28, 2002 | 05:11 AM
TsunamiZC's Avatar
Default Re: Problems of adaptation for the Ecu (typer558)
niceundercarriage, not a bit of sounddeadening , or protectant tar....kool ...i havent heard anyone with that problem around here, but you might wanna check club rsx , they have alot more rsx owners than we do on H-t
Old Aug 28, 2002 | 05:20 AM
typer558's Avatar
Default Re: Problems of adaptation for the Ecu (tsunami_zc)
ok, now I try
kahn_v
Jun 24, 2015 07:27 PM
billybong91DA
Feb 1, 2004 01:53 PM
preludacris
May 12, 2003 05:41 PM
