b16b?
Old Sep 23, 2009 | 05:36 AM
061000rr's Avatar
Default b16b?
hey im trying to find out what internals are in a b16b. im trying to put together a quick little all motor bulid for my work car. i have a b18c block with busted pistons, and i have a couple b16 cranks and heard that the b16b runs that crank. looking to do 12.5:1 cr. does anybody no what rods and what pistons to use?
Old Sep 23, 2009 | 06:15 AM
deckster333's Avatar
Default Re: b16b?
your question is a bit confusing... If you have a b18c block why not use b18c rods and crankshaft?
The b16b block is the same as the b18c but due to crank/rod dimensions it is destroked to a 1.6.
Old Sep 23, 2009 | 06:29 AM
97CTR's Avatar
Default Re: b16b?
Exactly why would you want to destroke a b18c? If thats what you are set on, then yes a b16b crank is the same stroke as a b16. The b16b rod length is different then all other b series rods.
Old Sep 23, 2009 | 06:43 AM
061000rr's Avatar
Default Re: b16b?
i want to destroke it to have a better rod ratio. this is my first all motor build, i've only ever done turbo builds. im just looking to do something diffrent. im looking for a high reving engine. and in reply to 97ctr the rod length was what i was worried about. so i would have to have rods and pistons then to get the ctr ratio. ok, do you by chance no if i can use the b16a crank with the type r rods and is there a piston that would work to get around 12.5cpr or would i have to get custom ones?
Old Sep 23, 2009 | 11:30 AM
Default Re: b16b?
b18c block + b18c head + pr3 usdm b16 pistons = 11.7:1 CR
b18c block + b18c head + p30 JDM b16 pistons = 12:1 CR
I would start there.
dont worry about revving high, youll rev plenty high with b18c and make more power. people spend alot of money to upgrade their 1.6 to a 1.8 L.
Old Sep 23, 2009 | 12:02 PM
KYSI's Avatar
Nil Desperandum
Default Re: b16b?
Yes, yes they do and worth every penny.
Old Sep 24, 2009 | 02:08 AM
EG6 Master's Avatar
Default Re: b16b?
that is exactly the same build i am doing but i am using a 85.5mm resleeved B18B block for mor displacement, 1.72 rod ratio, and mor compression.
u wil need custom pistons for that compr. ratio
B16B rods are 143.45mm long but they are narrower at the big end and the piston end by 2mm. u can use the pistons but not the rods.
Stakis
18
Apr 24, 2018 06:34 PM
91Honda_gsr
Engine Machining & Assembly
Dec 17, 2015 02:21 PM
viciousef9
10
Mar 18, 2009 05:25 AM
beyondstock
Mar 8, 2009 12:41 AM
Deetz
Sep 21, 2004 01:36 PM
