P8R Built Head, Crower, STR, 404 Cams
Brad S.
804 929 6995
price: $700 Complete
I have a JDM P8-R head forsale. No longer need this head and its up forsale.
These heads flow simlar to a OEM B16 head but are Non-Vtec. The chambers are 84mm also so compression will drop about 10-20psi in each cylinder VS a normal p75 pr4 head.
YES you can use this with a 81mm block. I installed one on my brothers car last year and he drove 30k miles delivering pizzas with no issues in his NA Civic Hatch. I put this Built one on my setup and ran it for 6,000 miles with no issues on a 81mm LS on 20psi of boost.
My *** dyno says this is a great upgrade, so get your *** a p8r head also!
P8r Head, Comeplete (450
Crower Dual Valve Springs
Crower Ti. Retainors
Crower 404 Camshafts (300)
Fidanza Cam Gear (50)
STR Intake Manifold. (350)
OBD2 valve cover
If separated, prices marked beside item.
Brad S.
804 929 6995
OBD2 valve cover
