92 accord problems
Old Sep 22, 2009 | 05:11 PM
Frank Allen's Avatar
Default 92 accord problems
my 92 lx starts up when cold and misfires on 3 and sometimes 2 cyl and runs a few mins then clears up and runs fine, i had replaced the plugs wires and dist capa nd rotor, i have no warning lights or check engine. i do however see oil in the sprk plug tubes and plan on replcing the seals. would this cause this problem?? car has 152000 miles. thanks
Frank Allen
Old Sep 22, 2009 | 08:44 PM
alkoholikwun's Avatar
Default Re: 92 accord problems
spark plugs and oil do not mix, definitely a problem here.
Old Sep 23, 2009 | 10:10 AM
P_Adams's Avatar
Frank Allen
You may have a few fuel injectors that are leaking down during the night, flooding those effected cylinders. Once these cylinders start pumping, the excess gas goes out the pipe and the fuel mixture gets to the point that they start contributing.
I'd run a few cans of injector cleaner thru and see what happens first.
P
DowneyB
Jan 3, 2019 01:46 AM
817cmr
Feb 23, 2016 11:06 AM
SlowDA9teg
Mar 31, 2014 05:31 PM
Accordion2
Mar 10, 2006 05:55 AM
