FS/WTT: 93 Integra LS/B17a1/Milano red
1993 Acura Integra
Located in Mason City, Iowa
143,000 miles on the body and 113,000 miles on the engine. currently getting 35 mpg!
- The engine runs great. doesn't smoke and doesnt have any leaks
- LS Transmission is in good shape no grinds.
- B17a1 out of a GSR
- GSR cluster
- Ecu is stock GSR from a 92-93
- lowered on coilovers not sure on the brand. decent ride not bouncy. had the front struts switched out for some in better shape.
- 2inch cat back exhaust with Magnaflow muffler.
- Interior is mint no rips in the seats. Dash has zero cracks
- front camber kit installed 50 miles ago.
- power windows and mirrors
- 92-93 GSR wheels with Si center caps
- 6000k HIDs for low beams. they have been adjusted properly. no glare like most
- front and rear strut bars
- small wire tuck ( more being tucked as the days go by)
- will come with Ek side skirts (not installed in pictures)
- fusion tires in good shape with minor camber wear.
- power moon roof
- rear wiper blade deleted and plugged
- Fresh oil change
- new spark plugs
- will come with a different valve cover with fresh paint . Unless you have some cash for the one in the pictures because it is Garrett's
The Bad:
- typical honda rust 1/4 panel and by gas door
- front bumper has chips / cracks in the paint
- starter is intermittent ****FIXED****
- No A/C P/S or Cruise
- no stereo but all speakers are intact. (Pioneer)
- dents in drivers door
The pictures should explain everything else.
Price: $1800 or trades
- GSR cluster
- power moon roof
- Fresh oil change
- new spark plugs
The Bad:
are you interseted in a 1991 crx si with gsr swap?
little bit of cash on your end.
http://www.hondamarketplace.com/show....php?t=2657739
