b21 vtec?
i have a 90 prelude with a b21a1,ive heard that a b20 and b21 are the virtually the same except the b21 is bored out, now with that said ive heard of people putting a vtec head on a b20,does that mean that i can put a vtec head on the b21?
yes but i dont like how low the oil pan sits below the frame with the h22.ive seen some where the oil pan is like 4 inches off the ground at stock hight and mine is lowered so if i swap ill scrape evey little pebble
After that, the tuning was another cost that was high.
If you want real power, you need to either turbo charge or swap to the H22/23.
Since height is an issue for you, I recommend you go the route of turbo charging.
I personally just finnished my H23 swap and once I get the Traction bar, I will lower it down again, but not as low as before. But I own the Ksports as well so I am able to stiffen my ride to keep the pan or down pipe from hitting anything.
I love the power of the H22/23 in NA form for the 3rd gen, reliability and great power.
FMIDRC Racer
Dec 20, 2003 07:28 AM
