swapped my 88 civic cluster with 91.. trouble?
I put in a 91 cluster in my 88 civic (almost identical cluster). the plugs in the back fit fine, but when i turned on the car the gas gauge doesnt work. also the engine light was on. So then I drove away and speedo worked fine so iv been driving it like that for now. a month later now the speedo seems to read lower then im actually going...almost stuck or something...its about 20 km/hr behind only when going over 120. but at low speeds its acurate!!?? hmmmm
IS this all because of the cluster, i obviously think the gas gauge is because of the cluster, but why all of a sudden is my speedo ****ing up.
Do 91 clusters function with the 88?
thanks guys
thanks guys
Here is a diagram from an old post, what exaclty do i have to do to make it work? just cut some wires? Dont really understand it. any help would be great!
http://crxcommunity.com/viewtopic.php?p=65118
i need help with this as well I set up my 88-89 dash harness to the 90-91 specs, and my cel stays on but it doesnt flash when diagnosing for codes. temp, and fuel dont work either. any help thanks
wongburger
Dec 13, 2009 08:39 PM
kizner
Dec 30, 2005 05:44 PM
CalhounBoi
Sep 1, 2005 10:52 PM
