no check engine light
i bought car bout 2 weeks ago, i just noticed when i turn ignition on there is no Check engine light. I removed the gauge cluster but all I see is 4 bulbs big ones and that's its . on my 96 civic there was like 12 of em for everything. here there is only 3 or 4 big ones. I want replace it. Also my mi-liege counter stopped working both of em. the one u can reset and the main one. they both stopped working 2 days ago HELP please
your in the accord forum bro.....but i would imagtine the buylb for the CEL may be out and the speedo/odo may have a bad board....replace cluster or repair it
the 4 big bulbs should be general illumination lights...you may have to dig into the cluster further but each warning indicator has its own small bulb( think about it 4 big bulbs and upwards of 8 or more warning indicators that can go on one at a time)......start carefully taking it apart as some of the bulbs may opnly be accessible by taking the actual gauge faces out....to take the actual gauges off you will need to loosen the screws to each one...but make sure you keep them in order as some of the screws are longer and the cluster uses the screws to send power
Nathan_volcom
Jun 10, 2012 09:34 AM
Zhu962
Nov 18, 2008 07:23 PM
ej6hatchie
Mar 5, 2008 09:44 AM
HondaHemi
12
Dec 21, 2005 01:17 AM
