crx body parts
Old Sep 21, 2009 | 07:18 PM
Sipocketrocket's Avatar
Default crx body parts
i bought a rear bumper for my 1991 crx dx and it wont line up right its not that bad but it seems to big or something??? which brings my question are all crx 88-91 body parts. doors, bumper, fender, lights etc. the same?? thankyou
Old Sep 21, 2009 | 07:27 PM
crx_si-r's Avatar
Default Re: crx body parts
all parts are interchangeable. are you sure your lining it up right? is it bulging out at the sides? if so then its has probably been sitting in the sun and re-shaped itself with the heat.
Old Sep 21, 2009 | 07:36 PM
kLt's Avatar
kLt
I got the same question i got a 89 hf but bought a 88 si front and rear bumper will it line up the same with teh stock fenders?!?
Old Sep 21, 2009 | 07:38 PM
crx_si-r's Avatar
yes, there is no difference with the 88-89 in style. since you have an HF model make sure you re-use your stock bumper support
Old Sep 21, 2009 | 10:46 PM
kLt's Avatar
kLt
another question, do u need the front bumper support cause i dont have one only have the rear??
Old Sep 22, 2009 | 05:30 AM
crx_si-r's Avatar
you have an HF, so look at just above your horn. you should have a block with something that resembles a shell. that is welded on to provide extra support on the bottom of the HF's set up because their bumper support is pretty much a bar of sheet metal. here is what the DX and Si support looks like
Old Sep 22, 2009 | 05:42 AM
~sp33~'s Avatar
EFB055
It's so heavy it cracked the road ^^^ lol
rexracer626
10
Feb 10, 2010 07:21 PM
rbondreviews
Aug 21, 2008 08:11 PM
88Hatchy
Aug 9, 2008 05:50 PM
CaptSandwichBag
Mar 5, 2004 09:46 AM
