Building a gsr head (recommendations)
Old Sep 21, 2009 | 06:37 PM
TougeCoupe's Avatar
Default Building a gsr head (recommendations)
Okay i searched but didnt really coming up with anything ive got my head i just picked up at the machine shop getting checked and it's good it's a 94 gsr head im going to turbo car eventually so what parts are recommended for na to turbo use and im looking for maybe 300-400 hp and i don't really want to break the bank.
Old Sep 21, 2009 | 06:58 PM
ohsnapzafingcu's Avatar
I serve phở for my babies
Default Re: Building a gsr head (recommendations)
if you are talking about internals, you can always benefit from some aftermarket valvetrain to accommodate the higher hp produced by the turbo. a set of cams would do wonders too.
i'd most definitely ask the machine shop to do a valvejob if you already haven't
Old Sep 21, 2009 | 07:05 PM
TougeCoupe's Avatar
So what aftermarket valvetrain should i look at specifically and the valve job is going to consist of what
Old Sep 21, 2009 | 07:28 PM
are you going to daily your motor? or is it for race only?
if you are going to daily it and plan on driving the motor for awhile i hear the Crower cromoly retainers last for quite a while, matched with their valvetrain
but if you just want something for a piece of mind, skunk2, supertech, eibach.. etc will work
and for a valvejob i meant a 3 angle valve job
Old Sep 21, 2009 | 07:33 PM
TougeCoupe's Avatar
Im going to be driving it daily also
Old Sep 21, 2009 | 07:41 PM
TougeCoupe's Avatar
What do you think about valves get new ones or keep the old and is it alright to use new stock valve stem seals with this setup
Old Sep 21, 2009 | 09:03 PM
HondacivDX's Avatar
get new ones if you already got the head off might as well do it right get new ones so u have no problems down the road
Old Sep 23, 2009 | 02:48 PM
TougeCoupe's Avatar
but do i get stock ones or aftermarket
Old Sep 24, 2009 | 06:56 PM
HondacivDX's Avatar
aftermarket
Old Sep 24, 2009 | 08:32 PM
riceburner700's Avatar
i would get a 3 angle valve job done. some new valve seals. get the head all cleaned up and throw the stock cams and valve train in the head unless your revving higher than get some supertech duel springs. the stock head and valve train will flow easily to 400hp
spluvs2install
May 7, 2008 08:14 PM
TwistedHatch
Oct 22, 2003 03:28 PM
rOby
Sep 17, 2002 08:23 PM
