CEL code 41,65 and speedo doesnt work?
Old Sep 21, 2009 | 05:26 PM
domenic's Avatar
Default CEL code 41,65 and speedo doesnt work?
hi, had some exhaust work done on my car, as i pulled the car off the hoist, check engine light comes on, i'm sitting idling and speedometer is moving and bouncing around. thought that was odd..
I went to get car scanned, those 2 codes came up 41 and 65, i replaced both 02's and also speed sensors but still same codes, tried 2 other computers and same.
i checked the ground and they seemed ok. i could not get power from the 3 when checking for power. could it be the wiring harness?
97 civic si coupe
please help. fuses also seemed to be working.
Old Sep 21, 2009 | 05:30 PM
JDM_SOHC's Avatar
Default Re: CEL code 41,65 and speedo doesnt work?
check fuse # 15
Old Sep 21, 2009 | 08:04 PM
Former User's Avatar
Originally Posted by JDM_SOHC
check fuse # 15
Yep. If 7.5A dash fuse 15 is blown, then read this TSB.
Old Sep 22, 2009 | 05:37 AM
JDM_SOHC's Avatar
Old Sep 22, 2009 | 08:37 AM
Hydra's Avatar
New User
thanks for this info my car's problem is sorted now!!!
Old Sep 22, 2009 | 06:32 PM
JDM_SOHC's Avatar
no problem dude, glad it worked out for ya
b18c-gsr
Jan 30, 2025 04:40 AM
ej6kevin515
Jan 18, 2012 04:47 PM
Superide
18
Aug 30, 2011 12:45 PM
Bulli Kid
Jun 5, 2008 02:13 AM
asianspeed
Nov 19, 2002 09:20 PM
