civic core support
Old Sep 21, 2009 | 05:07 PM
buda18's Avatar
Default civic core support
there are five screws that hold a 92 civic bumper to the core support. i had a hard time removing those screws from my car so i had to drill them out. anyone have any ideas for a good way to secure the bumper back to the core support? the metal is thin, so i'm assuming drilling out a bigger hole and tapping it would not work. any ideas?
Old Sep 23, 2009 | 03:15 PM
buda18's Avatar
Default Re: civic core support
ideas?
Old Sep 23, 2009 | 03:56 PM
bar'dh22's Avatar
weld a new nut on the under side
Old Sep 23, 2009 | 04:52 PM
Adam West's Avatar
Should of used a vice grip man.
Drill a hole big enough to accept the plastic bumper clips that are used on the EJ chassis
Old Oct 1, 2009 | 03:36 PM
Dimazz's Avatar
New User
Drill large holes for clips, weld nuts onto the backside, use a nut & bolt and just tighten with 2 tools.
Old Oct 2, 2009 | 10:52 AM
per4mance's Avatar
drill the holes out enough to put a 10 mm nut. Use the kind of nut that is on the Alt power wire. Thats the kind that has the washer or lip built on. Flip the nut up side down, where the bigger flat part is on top. Now tack them in from the bottom side. I have mounted battery trays, and intercoolers this way without anyproblem. Plus its a flush fit. If there isnt enough room on the bottom, tack them on top then grind them down flush then paint. Its really easy
Old Oct 2, 2009 | 10:43 PM
dirty19's Avatar
Ridin Dirty in Cali
Nutserts?
Old Oct 12, 2009 | 09:59 PM
lordtavo's Avatar
nutserts or wellnuts
Old Oct 20, 2009 | 02:17 PM
RickyLee53's Avatar
x2,
Get the cable ties out.
EK9JSPEC
13
Mar 24, 2012 11:06 AM
SMOOTHN
Paint and Body
Apr 13, 2011 10:03 AM
bijou
Mar 6, 2009 08:06 PM
RedEG8
12
Dec 12, 2008 11:53 AM
about:blank
Mar 26, 2008 07:48 AM
