d15b2 vs d16a6 flywheel, are they the same??
No, its in the middle of the flywheel, when you have your tranny out looking at it, its where you slide the flywheel in the middle, should have 20 spline.
JDMPR: that would be the clutch disk you're thinking of, obviously not a flywheel.
OP: flywheels vary in diameter between years. They are interchangeable as long as you have the matching clutch disk & PP, regardless of year.
immalooser
Oct 18, 2005 08:08 PM
