stage 3 clutch and 12lbs flywheel
I recently just installed this clutch and flywheel, and i find that at lower rpms it wants to buck and stall out, so its real hard to ease into it now, is this because of it being stage 3 adn that light of a flywheel or is there something not right?
something new started happenin....now when the clutch isnt down the car vibrates, as soon as i put the clutch in it stops to no vibration at all...what would cause this?
Just installed a stage 1 clutch and 12lbs flywheel today.. I notice that sometimes if im too easy with the clutch it bucks alittle bit , im sure with your stage 3 you gotta just be sure footed ...
About the vibration no idea.. but id listen and see if you hear any rattles outside the car and try to track that down , maybe some loose bolts? Good luck
reset2k
Apr 12, 2006 05:15 PM
beandip
Nov 23, 2003 11:31 AM
