motor swap?
Old Sep 21, 2009 | 04:00 PM
alwazjeepin98's Avatar
New User
Default motor swap?
maybe dumb question but i have a 96 civic ex i think w/o v-tech it doesnt say it on valve cover. its a d16y8. motor is bad, i just need car for commuting pruposes. but i also have a 94 d15b7 motor that is good. can i swap them out without any trouble? thanks for the help.
Old Sep 21, 2009 | 04:03 PM
derrickEJ8's Avatar
Default Re: motor swap?
I'm pretty sure the y8 is v-tech. I know mine is.
Old Sep 21, 2009 | 04:28 PM
alwazjeepin99's Avatar
New User
well it doesnt say vtech...so idk
Old Sep 21, 2009 | 04:29 PM
derrickEJ8's Avatar
There should be a little solenoid on the left rear of the head next to the distributor.
Old Sep 21, 2009 | 04:36 PM
Civicfanatic_09's Avatar
The Y8 is V-TEC, and you could swap in the B7 in there, but have to swap the oil pump, and the injectors, and distributor. Obd2 motors, use a crank position sensor that is on the oil pump, that the obd1 motors don't use.
Old Sep 21, 2009 | 04:37 PM
bigislandc2's Avatar
almost all ex have vtec. the solnoid is next to the dist. front side and some rear infront the int. mani. why do you want to swap out motors?
Old Sep 21, 2009 | 07:31 PM
New User
cause the y8 in it is bad, can hear a valve hit the piston.i dnt wanna put money into this vehicle. and i have a b7 layin around so i figured just use that. so can anyone tell me what to do about the extra sensors?
Old Sep 21, 2009 | 08:39 PM
98civdx's Avatar
Master Detailer
all y8s are vtec.
the problem with d15 is its obd1 and the car isnt... so youll need to switch everything over from the y8 and possibly do some wireing. im not 100%, but it should go in just fine, with out trobule no way, its not possible....
try and find a good y8 long block and switch it out.
gizzm619
May 13, 2009 10:51 PM
khmaiabz
Oct 4, 2008 02:12 PM
Manny86
Feb 24, 2007 08:48 AM
1990si
11
Jul 10, 2006 09:18 PM
dw.VTEC
Nov 28, 2004 09:46 PM
