ASR Subframe Reinforcement install trouble
Old Sep 21, 2009 | 12:46 PM
SoTexDC2's Avatar
Default ASR Subframe Reinforcement install trouble
I'm having problems getting my ASR Reinforcement kit installed, It's not sitting flush with the rear subframe on my GSR. With the LCA and counter sunk bolts head tightened, It appears as if the top mounting point needs to be shimmed to level everything out. Or is there supposed to be a gap between the highest bolt and the subframe?
I purchased the kit second hand (BNIB) from a Del Sol owner, and I was told that it will work on a DC chassis. I downloaded instructions in PDF format, but there isn't any pictures of the back side. Could anybody confirm that I have the back plates assembled correctly?
This is also the first time I have seen the kit with phillips screws on top.
Any insight is appreciated, i'll get some close ups of the subframe and gap after my camera charges.
Old Sep 21, 2009 | 01:25 PM
SoTexDC2's Avatar
Default Re: ASR Subframe Reinforcement install trouble
I pretty much answered my own questions here. I have everything orientated right, but the guy I bought the kit from did not give me the correct bolts. The ones I was trying to use were too short.
My subframe also looks like it may be bent towards the rear of the car. I'll find out when I get it aligned.
norcal450
Honda Civic (2006 - 2015)
Apr 30, 2007 02:34 PM
RicharDC4
Oct 27, 2005 01:53 PM
Sam268
Sep 9, 2004 03:48 PM
1SIKCRX
Jan 29, 2004 10:20 AM
