What is the compression (psi) of a obd1gsr (on a compression test)
Like the title says, I am going to do a compression test on a gsr motor I am buying later today could anyone let me know roughly what a stock bore stock compression gsr motor should have.
just make sure they are all almost identical. if one is like 20psi lower than the rest there is probably a problem with that motor
I know they should all be relatively close together I was just wondering the number (psi) they should be around.
The exact number depends on a lot of different things (like altitude, type of tester, battery voltage, exact method of testing, etc.). 170 is probably a good ballpark.
