best B series engine block ?
Old Sep 21, 2009 | 05:57 AM
pnutz's Avatar
New User
Icon2 best B series engine block ?
im tryng to do lsv-t and im wandering what will be the best bloock to start off some one told me the best one is from an 93 ls but im nnot sure. i also wander what ill run better lsv-t or just ls-t
Old Sep 21, 2009 | 06:10 AM
Furyof4's Avatar
Default Re: best B series engine block ?
The best ls block is the lowest milage, cheapest one you can find. There is no difference otherwise besides a few different sensors.
Old Sep 21, 2009 | 06:34 AM
skidmarkroyalty's Avatar
ya as far as i know they are basically all the same.
Old Sep 21, 2009 | 09:47 AM
big_daddy234's Avatar
wouldent the bottom end of lets say the b18c5 be a little better then that of the b18a1 which doesent handle near the rpms? i would also amagine they balance the rotating assmbly to a further degree also
Old Sep 21, 2009 | 09:59 AM
sh!ft's Avatar
Who the fack changed my title?!
i would have to say there are only 2 blocks that i like imo(without stepping into the k series topic) but id have to say the ls series from a 92-94, and the b20 series from the 96-2000. NO PRELUDE B20'S
Old Sep 21, 2009 | 10:40 AM
Ass$nyper's Avatar
Pirate General...YARRRR
What are your goals OP?
ls vtec or ls uses the same block....
As said before it's all in where sensors are comparing years of the blocks.
Some cases a different block might suit you better.
Old Sep 21, 2009 | 10:49 AM
D16SiHatch's Avatar
its true. the c5 is a hand-built engine. but if you had a type r bottom end you wouldn't be making an ls-v, you'd just be reassembling an engine that was already vtec to start with. the idea of an ls-v is you take a non-vtec lower revving block b18a1/b18b1 and build it to handle the higher rev's and modify it accordingly to support the vtec head.
Old Sep 21, 2009 | 04:16 PM
beansandrice's Avatar
Just make sure you run a brand new O.E.M. Oil pump a GSR girdle and get a Golden eagle or Datum1 LSV oil line kit. Dont forget to buy a new GSR/B16 water pump and a GSR belt.
I also have the Arp LSVtec Studs. No problem at all.
Old Sep 21, 2009 | 04:49 PM
sh!ft's Avatar
i always wondered what one i was going to use. now i know! thanks
H2B
14
Feb 3, 2015 07:04 PM
d15bvteKKK
Feb 9, 2014 02:19 PM
EJ2GOON
Engine Management and Tuning
May 1, 2012 05:01 AM
imissmyhonda
Oct 23, 2007 08:22 PM
