Suspension & Brakes Theory, alignment, spring rates....
Shock Mount Spacer
Old Sep 21, 2009 | 05:28 AM
1.5Slowmatic's Avatar
Default Shock Mount Spacer
I need to know where i can get the shock mount spacer to use the shocks on a 96-00. I have a set of illumina shocks and of course they are made to fit 92-95 no problem but wont fit my 00 one so where can i find one or can someone give me specs. I can easily have one machined by my friend or i could do it too just gotta have specs
Old Sep 21, 2009 | 11:31 AM
TunerN00b's Avatar
Default Re: Shock Mount Spacer
What exactly is a shock mount spacer?
Old Sep 21, 2009 | 05:38 PM
PIC Performance's Avatar
You just need 10mm total of spacers (5mm on each side of the bushing) with 10mm ID. As far as I know there is no special spacer out there, the washers work fine.
Old Sep 21, 2009 | 08:17 PM
o ok. i called tokico today and they gave me their specific part number since i bought the shocks from my friend who i assume threw them away since he had them on a 94.
Old Sep 25, 2009 | 01:32 PM
batallic's Avatar
u can use washers to take u the gap between the fork and the lca
COSMOS-1
Honda CR-V & Element
Jan 16, 2016 06:43 PM
beanbag
13
Jan 21, 2012 10:49 PM
no2psi
Welding / Fabrication
Dec 30, 2005 07:09 AM
Honda F1
Jul 15, 2004 09:56 AM
