Will a steel oil pan fit the D16Y5?
Old Sep 21, 2009 | 05:01 AM
mr.speaker's Avatar
Default Will a steel oil pan fit the D16Y5?
I cracked a big hole in the original aluminum oil pan,just wondering if I could use the steel oil pan from the 96-00 DX/CX/LX engines because there are aftermarket steel pans for $50 compared to around $200 for aluminum.
I've searched but there are no definant answers.
Thanks in advance.
Old Sep 21, 2009 | 05:34 AM
JDM_SOHC's Avatar
Default Re: Will a steel oil pan fit the D16Y5?
The pan will fit w/ no problems, but you may just want to double check that the oil pickups clearance is the same.
Old Sep 21, 2009 | 07:46 AM
mr.speaker's Avatar
Thanks for the response.
I'll wait for an answer about the oil pickup clearance as I don't have access to a spare oil pan.
Old Sep 21, 2009 | 07:53 AM
JDM_SOHC's Avatar
No problem
Also, you could just use a tape measure and take a measurement of the depths of each pan, if both are similar I'd say you're good to go.
Old Sep 21, 2009 | 02:23 PM
mr.speaker's Avatar
bump
Old Sep 21, 2009 | 05:52 PM
mr.speaker's Avatar
bump
latinman07
Jan 2, 2013 10:01 PM
K20A2 5 lug EG
Aug 6, 2008 11:50 AM
Foozball26
Sep 20, 2002 09:11 AM
