CRX with LS swap having a couple of issues
i am having a few small problems with my LS swapped rex
i am getting code 1,9,12,and 43
the idle is very high 2500rpm (was 3k but i idled it down all the way) i just swapped the thottle body and but on a different tps dont know if you have to adjust never messed with them the old one made it bog real badand stalled occasionally after the clutch was pressed in (could keep it running if you gave it gas)
any help would be great thanks
check what those codes mean. i could tell you but i think searching would help. fix check engine lights. and see if it still has problems.
1 o2 sensor
9 cylinder sensor
12 exhaust gas recirculation lift valve
43 Fuel supply system
also im running this on an obd0 PR4 ecu
9 cylinder sensor
ok is your o2 sensor hooked up? it should be a 1 wire o2 sensor, and as for cylinder sensor is your crx a dx or si? did you do dpfi to mpfi conversion? if you did, then check your connections or wiring, you probably wired wrong, and for fuel supply, make sure your fuel pressure regulator is good by checking fuel pressure, make sure the vacuum hose from regulator is hooked up to manifold, cuz when mine wasnt on my ls in my ef, it gave me that code. and code 12 is for A/T tranny only, so that means you have an auto pr4. not sure if that will work or not do some research on that or somebody help me out with that one
my crx is a HF
the car was like this when i got it i just found a bunch of **** wiring under the dash tho dunno what they did to it probably more bootleg wiring (the car is mostly wiring issues now)
may pull my harness from my 89 si and see what i can make of this
fuel pressure shouldnt be an issue as i have a walbro 255
ok now 9 and 43 are back i mess with the dizzy it dosent bog as bad but surges when i set it close the middle it bogs real bad barely even inches foward for a couple of seconds nut dosent surge much if at all is my dizzy at fault here or what?
existanzcivicb20
10
Jun 6, 2016 06:18 PM
back2basics
May 25, 2010 05:46 PM
Perfectionist
Oct 8, 2006 02:00 PM
importdude2000
Dec 16, 2004 11:45 AM
