How do you wash and wax your car
Old Aug 27, 2002 | 09:45 PM
VTECTIME's Avatar
Default How do you wash and wax your car
I want to know from the Honda-Tech pro's how you wash and wax your car? Any tips or special things you do to make your Honda shine?
Old Aug 27, 2002 | 09:48 PM
IdotheSHOCKER's Avatar
Default Re: How do you wash and wax your car (VTECTIME)
Get a buffer and do it while its cool outside and shaded. dont do it in direct sunlight and try not to get it on the plastic pieces. Don't leave the wax on tooo long.
I learned the hard way with my first CRX.
Take your time.
Old Aug 27, 2002 | 09:50 PM
nxz0's Avatar
I don't remember where i found this but it's very informative and long.
Keeping the body nice and shiny....
Article by Mark Impact23 First off I have to give props to where it is due. I learned a lot about keeping the FBP swirl-mark less with he help of some ClubSi buddies of mine. But these are the basics steps and you will be really happy with the outcome of this if you show and take pride in the appearance of your ride.
To help us all out, I will outline general method of professionally detailing your car. I do this about twice a year (or every 7500 miles). This is just an outline, and I hope to supplement this with more articles in the future regarding specific steps in the process. Also, you should keep in mind that each individual car has its own challenges in detailing, so use the following as a resource that you might refer to in the future!
A few tips before getting started:
1) Make sure you have ample time, it may take 6 hours or more.
2) Make sure you have all the necessary products to start with.
3) Help (in the form of a family member or friend) can make it go much quicker.
4) Perform all the steps in the shade if possible. If not, I suggest washing the car outside then drying it in the garage and performing all other steps in the garage.
5) Use only 100% made in the USA cotton, all other materials (with the exception of micro fiber) will scratch the clear coat.
6) If you drop any sponge, mitt, towel, don't use it again. It'll just inflict scratches.
7) Always default to the product instructions if they differ from mine.
Basic Detailing Outline
I. THE WASH
When washing the general method to avoid scratches is to use two buckets. One with just water and the other with car wash shampoo. Always rinse your washing tool (brush/mitt/sponge) in the water bucket before going to resoap. Also rinse the car frequently to avoid drying out the soap and leaving soap residue.
Wash first with Dawn. Buy the blue original formula. Use a few squirts in three gallons. This step effectively removes old carnauba wax (not synthetic wax). You will not need to wash with dawn every week, as it is meant to be a twice yearly wash to remove built up wax. Any more frequently, and it can quickly dry your paint out. Rinse immediately to avoid residue buildup.
Follow up (without drying off the water from the dawn wash) with a wash with a regular car shampoo. I like to use higher end car shampoo products because they are very mild, will not strip wax excessively, will often help sheet the water off your car, and contain oils to help keep your clear coat/paint from losing the oils in the paint. Pinnacle Bodywork Shampoo, Meguiar's Professional Hi Tech Wash, Meguiar's Gold Class shampoo, and P21s Shampoo are some examples of such good car wash shampoos.
Immediately dry your car.
II. CLAY
Clay your car. Make sure you follow instructions, use enough lubricant, and NEVER drop the clay bar. It will take out the grime, bird feces, water spots, particulate matter that can build up on your paint (before and after claying, stick your hand in a zip lock bag and run it over the surface of your car... you should feel decreased particulate matter on the car after claying). If you do drop the clay bar, use another one and throw that one away. Both Pinnacle and Mother's make great clay bars, but I would have to recommend the Mother's clay bar because of its low cost.
III. PAINT PREPARATION
Most detailers would agree that this is the most important step of the whole process. Properly done, it should remove grime, heel marks, oxidized paint, and other contaminants while renewing the paint's shine. It provides the basis upon which your shine will glow. At the very least, this step involves using a nonabrasive polish. However, if your paint suffers from severe swirl marks or light scratches, I'd suggest adding an abrasive polish to remove such defects in the paint.
A. ABRASIVE POLISHING (if necessary)
Apply the polish one panel at a time. Use just enough to cover the panel and work the polish in until a thin haze is left. Use only foam applicators to apply. This step effectively removes many swirl marks or light scratches by removing less than 1mm of your clear coat. If done less than 2 times a year, this will not hurt your paint/clear coat. I can only recommend a few products: 3m Perfect it II (or 3m Finesse it II although more abrasive) and Meguiar's Professional series fine cut cleaner. Always follow up with a nonabrasive polish.
B. NONABRASIVE POLISH
Same technique as with abrasive polishes. This will strip free all previous wax (carnauba and synthetic) that hinders your true paint color from coming through while helping to remove the residue, film, or very fine scratches that abrasive polishing can leave behind. I recommend Pinnacle paint cleanser, HD Cleanse by Zymol, Meguiar's Professional swirl remover no. 9, Meguiar's Premium Medallion Paint Cleaner.
C. GLAZE
Again, apply as with A and B. This step will help gloss your paint to bring out more shine while helping to fill in some of the swirl marks or scratches you couldn't get out earlier. I use and recommend only 3m Imperial Hand Glaze for this step.
IV. WAXING
Wax has evolved over the years, and the selection that it has generated can be quite daunting. Simply put, there are really two types of waxes: synthetic and carnauba. Synthetics are often made from polymers or acrylics. The benefits of such a wax is that it can last long, it can withstand greater abuse, and it can lock in the shine that step III has brought you. Its downside is the fact that it tends to give more of a reflective shine (mirror like). While some like this shine, I prefer the deep, rich gloss that carnauba waxes give. Carnauba is a Brazilian wax that is normally rock hard. To make it suitable for cars, companies will often combine chemicals that will raise lower the melting point of the wax, making it easier to apply. A downside to carnauba is that in dry or very hot climates, it will last 4 weeks or at most 6 weeks in less severe climates. If you are like me, I put both on. I first apply the synthetic for the long lasting protection. Then I add the carnauba to give the rich, deep gloss I prefer.
A. SYNTHETIC WAX
Apply with a foam applicator pad. Apply and remove as stated in the product instructions. Generally, this is the same as the techniques listed in step III: polishing. There is great variability on what people would use here. I use an expensive German acrylic called Klasse that is imported and was made because of German cars' finicky paint. I love it. A very nice shine and it can be layered. I usually add on two layers for extra shine. It also protects from uv rays, acid rain, some small chipping and can help prevent swirl marks somewhat. It also does not yellow. I would also consider Meguiar's polymer no 20. That has been used with success also and is cheaper. Zaino is another, but I will comment on this at the end of the article.
B. CARNAUBA WAX
Apply similarly to A. Note that this needs to be applied at moderate temperatures. Too cold and it won't settle correctly. Too high, and it doesn't solidify fast enough. Remember, it only lasts for 6 weeks, so I tend to relayer it every six weeks or so. It only takes an hour which is not much time for the great return you get. Products I recommend: hands down best is Pinnacle Souveran. I use this occasionally if I feel my car needs to be pampered. One Grand Blitz is cheaper but very very nice! Others include Meguiar's No 26, 3m Show Car Paste, and Zymol Carbon.
Now that you are done, all you have to do is enjoy it!
A word on Zaino. I like this product also, but the instructions for its application is much different than what I have listed here. Thus, I will refrain from making any statements regarding its usage. Refer their website for further information.
Also, many people like to use leaf blowers to help dry off their cars. I find this helps out a lot too as it keeps those towels from leaving any possible nasty swirl marks on your paint. That in combo with a good shammy... your paint will love you and shine like a mirror. Hope this helps everyone here... I know it is long but it is only twice a year it is needed. I will post up some pictures of the shine of my car and a few friends after doing this procedure when I get some time. Okay... I will go keel over now.
cliff:step bye step how to clean and deatil your car
Old Aug 27, 2002 | 09:53 PM
VTECTIME's Avatar
what did you do to yur CRX?
Old Aug 27, 2002 | 10:02 PM
innate's Avatar
use meguire's gold class car wash, use a washing glove, don't be stingy when using waxes and polishes, and do as much detailing as you can inside a garage.
also, get a friend to wash his car with you. the time spent seems a lot faster, easier, and funner even though you're now washing 2 cars
Old Aug 27, 2002 | 10:08 PM
Got wax all over the plastic parts... mirrors door jambs -- turned white and crusty never came off
Left wax on too long -- wax became a paint thinner...
and countless other stupid things I did to it, first car of course.
Old Aug 27, 2002 | 10:09 PM
ZeroEric's Avatar
Default Re: How do you wash and wax your car (VTEC CX)
anyone ever use a Turtle Wax Miracle Towel? good item or what? What would you suggest for a chammy? (isn't it spelled chamois?)
Old Aug 27, 2002 | 10:47 PM
grey16's Avatar
Default Re: How do you wash and wax your car (innate)
I wish I had a garage.
Old Aug 28, 2002 | 12:00 AM
CR-V's Avatar
Default Re: How do you wash and wax your car (grey16)
my car has 62,000 miles on it.. its still on original paint. the paint still feels silky smooth... i wash it every now and then(maybe once a month) and after i wash.. i wax it right away.. and i use mist/wipe detailer to keep all dust off the car at least 2 times a day. i drive 100 miles a day and its in the sun all the time, but if u keep a layer of wax on it.. u'll be fine. i recommend the mequire's GOLD CLASS paste wax.. just use that.. nothign else is needed.. and every few months use clay bar(follow directions on it). remember to wash, wax, buff and all that stuff in a cool spot.. oh yea.. zaino is good ****, but if u dont have like 10 hours of time to kill.. mequire's is fine... its cheaper, faster, and works ALMOST as good.. hey.. i drive a 100 miles a day and my paint looks better than some garage ******
Old Aug 28, 2002 | 06:31 AM
HondaChevy's Avatar
Hey if you want to get that car show shine are looking for really good products that will give your car a glass look to it and protect it really well take a look at www.zainobros.com . They have images of cars that have used their products and the result is amazing...I have been using it on my 96 Z28 for over a year...I had a custom paint job done and was looking for something better than what you could find at AutoDrone or O'Reily's. Also don't use a buffer you are prone to scorch the paint and use only 100% cotton towels without stiching...as for applying the soap same thing use only 100% cotton. Synthetic fibers will scratch your paint. Keep wax away from the plastics (panel and side moldings) unless it is a wax made for plastics. Also stay away from body crevices. This will reduce your chance of not completely buffing (by hand) all the wax of the car. Seriously--take a look at zainobros...the result is great and they will provide further tips to car detailing.
Hope this helps...
[Modified by HondaChevy, 7:32 AM 8/28/2002]
Old Aug 30, 2002 | 05:27 PM
type r 01-1063's Avatar
Default Re: How do you wash and wax your car (HondaChevy)
I live in So. Cali. Where can I get a bottle of Zaino for my car? Pep Boys, Walmart, etc.?
Old Aug 30, 2002 | 06:08 PM
deepnite's Avatar
i dont love my cars that much...wash...wax on/wax off ....4 times a year..takes shouldnt take more that 2 hrs...make fast..not pretty
WHiTETYPEs
Jan 23, 2005 05:37 PM
blackgrrl23
Sep 28, 2004 12:14 PM
Drews Bitch
Apr 11, 2003 12:05 PM
01nhbgsr
Nov 21, 2002 07:49 PM
