IL F/S or F/T 1994 (original) b16 Honda Del Sol BUILT! Toda Skunk2 Apexi More!
5000 obo
**AS OF SUNDAY OCTOBER 4**
i unpluged the vtec controller, and it now holds and idle and runs somewhat better, but the cel light went on, due to the ecu being stock.
$5800 obo!
very flexible on price since it needs a tune
Hey guys, up for sale is my 1994 honda del sol. It is an original b16a2 dohc vtec. Apparently these are actually pretty rare, and not too many were made with the b16’s. the engine has been built, professionally, it just needs a tune, ill soon get into that. But overall it’s a pretty decent car, still has A/C and P/S and its fast as hell!
Overall:
It runs pretty good now, I don’t get on it really, it needs the tune, the info is down at the bottom, but I love the car, its fast, it doesn’t leak any oil from the engine or trans, clutch is grabby, takes a little bit of time too warm up, but with the tune itll be fine, so it does need a little bit of work, and I wish I could finish but I don’t have the time or money anymore
Engine:
Toda vtec killer cams
Skunk2 Cam Gears
New Timing Belt
New JDM Head (been milled .20 over)
Skunk2 Valve Set
Skunk2 70mm throttle body
High Flow Cat (test pipe almost) NO CELS!
Skunk2 Full Exhaust
5Zigen Headers
Single Fan Radiator
Skunk2 Intake Manifold
AEM Short Ram Intake w/AEM Filter
Bottom End has been cleaned up
Newer Fluids
Oil is clean, no leaks, or burns!
Transmission:
GSR (5speed) Hydro Trans w/50,xxx aprox
L.S.D.
Exedy Stage2 Clutch w/Flywheel
Short Shifter
Newer Linkage
Suspension:
Full Coilovers
New Shocks
New Axles
Newer Bushings
Newer Control Arms
Skunk2 Camber Kit
Front Strut Bar
Brakes:
All Disc (not converted, original, with the b16)
Hawk Pads
Good Life
Electronics:
Apexi AFAC Vtec Controller
OBX triple pod gauge setup
Autometer Air/Fuel Ratio Gauge
Autometer Voltage Gauge
Autometer Oil Pressure Gauge (this one isn’t hooked up yet)
Bads/Needs:
The body has 195,xxx, but what do you expect for a 1994, no rust, but the paint is kinda faded and the rear bumper could use aligning, not too many dings or dents, clean body, just a lot of miles and paint faded a little, plus side has a carbon fiber hood and targa top!
It needs a professional tune, pretty badly, don’t get me wrong it runs like a champ, it just takes awhile to warm up and hold an idle, and some other minor things, not a problem at all, also it will need a new ecu, its still running on a stock one, so the cams and vtec controller are messing with the map sensor and the tune will help these both with a chip or ecu, right now I have it set up to run really rich, I rather have it run rich than lean anyday
The interior needs a little tlc, no tears in dash, but a little dirty and could use a little alignment as well, panels and such, no big deal, drivers seat has a tear and theres no cover over the ebrake handle, no passenger door handle, the alarm was so strong it poped it out and broke it haha on the plus its all power
The clutch needs to be bled, the peddle doesn’t spring up all the way so you have to reset it with your foot, no big deal just bleed the clutch, the clutch its self is new
Needs new rims, the previous owner had put 18s on haha, and they are a little rashed up the tires are brand new so if you like 18s then there you go, no problem there
Like I said overall it’s a nice car, fast as ****, just needs a little tlc ,have lots more pics, like of it in the shop and stuff, and more info just call or text me
TUNING INFO (EST. FROM MATT AT DS1 MOTORSPORTS)
175.00 for chrome setup with obd1 harness and all hooked up
75.00 and he.ll check all the wiring and make sure its right (gauges, vtec controller, ecu)
200.00 per hour for it to be DYNO TUNED not street tuned
so pretty much you can have it up and running right for 600 out the door, pulls hard now, runs good when its warmed up
text
847 385 1326
email
mik3st3rn@gmail.com
New pics as of monday october 5th
$5800 obo!
Overall:
Engine:
Skunk2 Cam Gears
New Timing Belt
Skunk2 Valve Set
Skunk2 Full Exhaust
5Zigen Headers
Single Fan Radiator
Newer Fluids
Transmission:
L.S.D.
Short Shifter
Newer Linkage
Suspension:
Full Coilovers
New Shocks
New Axles
Newer Bushings
Newer Control Arms
Skunk2 Camber Kit
Front Strut Bar
Brakes:
Hawk Pads
Good Life
Electronics:
Bads/Needs:
text
847 385 1326
mik3st3rn@gmail.com
looking for whatever kind of trades, shoot me offers, but no lowballing please and no piles
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/eMeIX2jeN2g&hl=en&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/eMeIX2jeN2g&hl=en&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
VIDEO :::::BUMPP:::::
http://www.youtube.com/watch?v=eMeIX2jeN2g
OOPS didnt know you cant embed videos, heres the link.
Somebody buy this del sol you will not be dissapointed.
Just so everybody knows the sol picks up real good
http://www.youtube.com/watch?v=oSitH02zeAg
http://www.youtube.com/watch?v=kNSfWYQlaaw
Bored video BUMP
Bored video BUMP
but not by much ) bump
