ls vtec not starting for the first time since rebuild!
ok i got a 93 integra b18a1 block, and a 01 jdm gsr head!
the block was fully taken apart and machined ETC and arp head studs and p73 new pistons and rings! and new EVERYTHING!
golden eagle ls/vtec kit, skunk2 manifold!
now i have vacum,fuel,ETC all hooked up and no leaks! everything has fluiids ETC!
i go to crank it for the frist time and it just keeps cranking, wont turn over!
is thier a trick to geting it to start for the first time?
i checked for spark i have spark i have fuel pressure at 42psi on my gauge and the car does crank!
everything is hooked up on the sensors! do i need some kinda sensor? im runing a p73 usdm ecu and obd2 harnes! on a 99 integra gs 5spd
can someone please help me! im freaking out! its my first b series build! oh and my buddy who builds motors built the motor for me lol not me!
Are youre wires in the correct firing order, timming and are youre inj correct connectors in the right place? did you try to swap out ecu with youre stock one? with fuel and spark youre vehicle should start theoretically speaking
I agree on checking the timing and firing order again.
Also, I don't believe this keeps the engine from starting, but have you addressed the crank sensor issue?
the timing is dead on! and iknow the firing order! imma check the injectors for some reason i have a feeling that they arnt priming! and im going to re check grounds and im going to add some grounds and see whats going on! thanks guys
? not sure about that body, i think u will have more luck performing a CPR in this situation
qazaq, his car is obd2. 99 Integra with usdm p73 ecu. I was asking if he addressed the crank sensor issue since only the block is obd1.
cylinder compresion!
4 3 2 1
230 240 230 215
its geting fuel and its spraying! and i regaped plugs to .40 which they were at.30
i added more grounds!
and i re did the timming! its dead on now! the car cranks and doesnt start!
and its a obd1 ls bock b18a1 jdm p72 gsr head and im obd2 using a p73 its a 99 gs integra 5spd!
anyone have anymore ideas?
4 3 2 1
230 240 230 215
the car should start even with out a ckp sensor.
try to swap the distributor.i know you said there is spark, but ive ran into sevral cars that there were spark and car didnt start, it would be intermittent. with the kv probe.
try to use youre old gs one it wont bolt up correctly but you can still use it.
ok i looked for spark! now i have no spark! i tried a known working obd2 p72 gsr ecu and car still had no spark! so im trying a new dizzy known working on my buddies car! so wish me luck and lets see if it was the dizzy!
ok everyone! it was the dizzy! it started right up! i got a lil leak from headgasket on the front tranny side;( damn lsvtec's i even bought the damn full golden eagle kit
oh well i gota figure out what to do! but other then that for its frist start up and my frist b sereis engine build EVER! it purred and sounded ****ing sweet! thanks everyone for ur help!
ssounds good yea that fooled me a couple of times. ls vtec alway leak in that cornor.well hope you have fun with it. more builds to come...
My LS/Vtec doesn't leak there, but I used a cometic gasket. Don't know how much that would have helped though.
ya i guess imm ahave to take off the head AGAIN ugh!! and put some honda bond and some cooper spray on the headgasket and reintsall it all and see what happens! damn lsvtec's lol but hey when it operates right.. they are a pretty powerful motor and have some fun with them lol! thanks everyone for ur help!
i have arp head studs and they are to specs and i had the whole block redone from the machine shop! it was even lazer decked for flatness! and i used the GE ls/vtec full kit with headgasket and all!
i was told lsvtecs leak on all 4 corners tthat i shoulda used honda bond and cooper spray stuff!
anymore feedback on this?
also, how do u know it's the headgasket? what/where is the leak?
i recently had problem with the car not starting and problem was the dizzy, even tho it only ran for few weeks after i bought it brand new. who would'v thought new dizzy would fail that fast.
