Engine swap trouble
Hey,
I just swapped out a blown b18a1 out of my crx and put in a b18b1. On the A1 there is a water return line on the back of the intake leading to the block, or vice versa. The trouble im having is finding where the the line runs to the A1 block from the back of the intake... anyone know where that is located??
Also I had to use the wiring harness off of the b1 motor cause the a1 was cut when pulled from the car i bought it from, so I had to splice some wires to get it to fit and connect to everything, such as the alternator wires. When i turn the key the starter kicks and the fuel starts running all the electronics work but no power makes it to the spark wires and plugs... again any guesses??
alacard
Jan 14, 2009 05:56 AM
Thudpucker
Feb 13, 2004 06:07 PM
coolusername
20
Sep 9, 2003 05:34 AM
