car doesnt start sometimes.
90 ex sedan. b16a swap. ran fine for since ~Jan.
just recently, the car started to not turn on, it would crank over and over and over but doesnt start. if you let it sit for a while it would starts up fine.
this problem occurs sometimes.
would a main relay play a role in this?
starter was replaced like last month with a perfectly working one.
yes it does when you turn the key to the on position b ut dont start it see if you can feel the relay kick if iot doesnt then its the relay if it does probably something else
If youre having trouble starting up when its warm outside its more than likely your main relay. Heres a way of resolving your issue if you dont want to buy a new one. http://techauto.awardspace.com/mainrelay.html
While youre working on it, relocate it and wire up a kill switch. No main relay, no start.
collkid
13
Sep 16, 2015 09:10 PM
nismogrendel
Apr 24, 2010 01:43 AM
stevew84
25
Jul 17, 2008 06:16 AM
EGk3nrock
15
Aug 29, 2007 01:00 PM
