d16 Throttel Body??
Ok i have a d16 with stock throttel body and my question is there is a screw that is to the left of the vaccum tube on top , for some reason the screw backed out and i put a bolt in it with electrical tape around the bod to hold it in place, then this also backed out now i put a plastic screw tap base thing with tape around it in there, my question is can this be sucked in and be sucked threw the throttel body down into my engine if so this would be very bad or is that just a channel and is blocked by the manifold part??? what should i do.
Thanks
Thanks
NiceCarsItsAllGood
Apr 2, 2003 06:16 PM
