brake boosbter delete??
Who the fack changed my title?!
So I picked up the octobers issue of super street and they dedicated this issue to a few hondas......unusual imo, but any ways, they did a feature on the ry-wire crx. And one thing that caught my eye was the fact there was no brake booster, just an adapter plate. By deleting the brake booster, does this mean no power brakes? Or is it the same? How can I do this to my hatch? Has any one done this before??
The Rywire car says that it doesn't use a booster but it still uses engine vac to give a decent pedal feel.
https://honda-tech.com/forums/showth...416694&page=27
Here is the build thread where he talks about it.
I know that in the last issue of project car their crx had the brake booster delete which looked sick. They have a good write up about it. They got it from chase bays, so you can find it there.
Its not a "brake booster delete kit" its a brake setup. Wilwood and a couple other companies have them here is a little info about it http://k20a.org/forum/showthread.php...aster+cylinder
JEEZ! DO I HAVE TO FIND IT!?
lol
at least everyone READ this for once.
lol
Originally Posted by chasebaysonline.com
Brake Booster Delete
* How does it work and what does it include? – We use an aftermarket master cylinder (Wilwood or Tilton brand) The size of the Master Cylinder we use varies from 3/4 to 1 inch, and which one used varies from car to car. The custom peice we provide is an aluminum plate to adapt the master cylinder to the car without cutting or fabbing anything. It also include an adapter for the master cylinder to OEM pedal so everything works proper, as well as all the hardware needed to install it on to your car.
* How is the braking? – The braking is good in my personal opinion, as well as the other customers who have tested it. The car stops in the same amount of time if the brake lines are set up proper from the Wilwood or Tilton master cylinder. Which require’s nothing from you if you purchase our brake line relocation kit (shame less plug!) The pedal feel is more solid than a well bled OEM booster setup so, if you weren’t expecting anything in a car you were driving the car would jerk forward. There is a few people running this on their daily driver with no issues and no scares. Im not going to reccomend it or NOT reccomend it but the car brakes perfectly fine for often drives and held up to our serious brake testing on Alabama mountain roads!
* When will the kit release? – Unfortunetly we have had some CNC machine shop issues and it is taking longer than expected. However by the time you read this everything should be ready and waiting to ship! We will be selling them in Machined look, and anodized black. Expect picture’s up soon!
the car would stop in the same amount of time regardless. Brake booster has no effect in braking distances. It plays a role in modulation and pedal feel/effort.
of COURSE the pedal is gonna feel more solid, you effectively changed it from an assisted brake pedal to an unassisted pedal.
however, the piston size in the master cylinder may have played a role in pedal effort... but I'm not smart enough to properly speak to this... ie. does the smaller piston make the pedal effort less or more in order to stop the car.
I think people don't understand what the braking system components do.
There really is no magic here... Smaller MC will have a "softer" pedal but will require more pedal travel. A car without a booster doesn't exactly feel like a car with a booster and the engine off. It is VERY possible to have a DD without a booster. Though, if you get used to that pedal feel, just be prepared when you get back into a newer car to go easy on the brake pedal, don't need to flat spot any tires.
The key is matching the MC size to the rest of the system. I'm sure you've all driven cars without power steering... it's very doable also, it just has its caveats.
Yeah, they decreased the m/c bore, so it would be 'easier.' Also, having a couple 'vintage' cars (pre brake booster) it's not the same feel as engine off at all. It's similar to the difference of having a car with manual steering vs. power steering with the car off (or belt disconnected).
i can remeber when i 1st started driveing , i had a ford with no booster , if we were hiting the streets hard and tryed to come to a stop fast we had to go down the gbox to help with slowing us down. but they were very driveably.
we also used bigger brakes too to help us to stop haha
my 2c
my 2c
Actually this is all basic hydraulics.
Using the formula::: Pressure = Force (in pounds) /DIVIDED BY/ Unit Area (inches squared) ::: you can use this to "reverse design" a brake system that has the "stock feel" with the same performance.
Pressure would be the amount of "line pressure" required to make the pistons push the pads/shoes to their appropriate counter parts.
Force would be the amount of force to press the master cylinder to compress the fluid, which actuates the pistons, to press the pads/shoes to their appropriate counterparts. This can be manual force provided by the operator with a provided amount of leverage. It can as well take place with assistance (brake booster) and a provided amount of leverage.
Unit Area would be the size the master cylinder (assuming the brake lines and calipers are the same size/length for all setups) needs to be for the desired effect to take place with a certain Force and Pressure requirement.
So with all considered you could easily see that to get X amount of pressure you can either use more FORCE to a smaller Unit Area (brake booster on a smaller master cylinder). To go the other route (NO brake booster) you would obviously need more Unit Area to get X amount of pressure, to use the same FORCE as an assisted brake setup.
Either of these setups can be changed around to have to use more or less force than the other. So if setup correctly, if the brake setups you people are talking about required more force to apply the brakes then it is a POORLY designed setup. It should be the same as stock, preferably not softer, because then brakes locking up may pose as a problem.
Oh well, I will stick with my brake booster…
S375CRX
Suspension & Brakes
Aug 18, 2016 04:15 AM
